Oppo PM-3 : The Portable Planar - Impressions
Jun 2, 2018 at 2:58 PM Post #5,566 of 6,302
Hi, thanks for the reply. Local temperature goes upto 41 Celsius and humidity can go upto 80 percent RH . However I use them mostly in Air conditioned environment. How is velour when compared to sheepskin leather? This is for the earpads . Oppo offers only pleather .
Jun 2, 2018 at 4:06 PM Post #5,567 of 6,302
I haven' tried them on the PM-3's, but I'm personally not a big fan of Brainwavz velour. I find it gets hot. Plus it would probably lower the bass a little bit, which isn't something I would want. Can't speak from actual experience with the PM-3's though, sorry
Jun 2, 2018 at 5:03 PM Post #5,568 of 6,302
Thanks. I think I will go with the sheepskin. I have an ipod 5th gen classic click wheel 60gb video version and the cowon plenue p1. The p1 picks more details ( sometimes not good ) and treble is good , but , bass seems subdued and the gap between the high and low of sound seems less. This is my experience with oppo pm3. Have to find out which headband option would fit the PM 3
Jun 13, 2018 at 3:28 PM Post #5,571 of 6,302
Hi, I got the sheepskin pads and after removing the old pads , I slipped these on. The angled ones are bigger than the original pm3. I felt the clamping force was more with these specifically the lower end pressing below ear. Has to do with dimensions of the pads and my ears and the positioning due to that. I found a simpler way of detaching the oppo pads. I took a pharmacy rewards card , dimensions similar to a credit card and inserted in between the earpad and headphone frame in the side. Then I pressed the plastic and pulled gently. The last steps were instinctive and one might need to experiment. The side clip opened with a click and rest was easy.
Impressions : reasonably comfortable. I had to pull out the headband a bit to compensate for the additional clamping pressure. Music on my cowon plenue p1 sounds more nearer to ipod and am enjoying it. More depth , little more pronounced bass. No degradation in music. Need to listen to more albums and also the ipod as well as the disc man for fairer idea of difference. It's bit big to fit into the hard case provided by oppo.
I have to figure out the headband replacement part. How does one take care of sheepskin leather ?
Thanks for all the inputs. The headphone aesthetics look reasonably fine.
Jun 14, 2018 at 12:00 AM Post #5,573 of 6,302
Would you mind posting a pic of them with the new pads? I'm getting new pads in tomorrow and I'm not sure how to fit them on. Do you just take off the old pads and slip the new ones over the whole earcup?
Jun 17, 2018 at 11:22 PM Post #5,574 of 6,302
HI, took off the old pads and slipped the new ones on.
Jun 18, 2018 at 3:39 AM Post #5,577 of 6,302
I emailed the support of Brainwavz for details on care for the sheepskin leather ear pads. They responded with a link and asked me to go through head-fi forum for details. I got the same response last time too. The link is a generic link, which speaks about care of earpads and I read it earlier. Their support seems a little weak.
Jun 18, 2018 at 9:54 AM Post #5,578 of 6,302
Jul 13, 2018 at 3:26 PM Post #5,580 of 6,302
Hi everyone,
I recently acquired a pair of Oppo PM-3 from someone else here on the forums.
I'm an IEM guy wanted to dip my toes into headphones. This would be my first pair of headphones. I needed something portable and can isolate somewhat alright on the subway. Also, sensitive enough to be driven by my Cayin N5ii.
Hoping it sounds good :) Also, any recommendations for a balanced cable? I hear it scales well. Ideally, not more than $100.
