x RELIC x
I emailed Oppo about HA-2 compatibility with iPod Classic 160 gb, and they said it would be compatible if it has iOS 2.0.3 or 2.0.4 software. Has anyone with these versions tried the HA-2 yet and, if so, do you think that the HA-2 DAC significantly improves the sound quality?
You can use the HA-2 audio jack in, but it would probably bypass the HA-2 DAC so it will only function as an amplifier.
Don't have the HA-2 but the full size HA-1 works with my iPod classic 120gb without issue using the 30pin cable. If Oppo says it'll work it really should work. If not then check the FW or cable. In my opinion it should be a significant improvement. I never really like the output of the classic.
