rickydenim
- Jan 23, 2015
There is but it is hard to find short ones: https://www.amazon.com/Cable-Matters-USB-C-Braided-Jacket/dp/B00UUBRX0Y?ie=UTF8&gclid=CjwKEAjwz4u9BRCbioK3stnBznESJADA75xbRGGw1rwnCWNhcspBKiXtM-CjZLO4QxN2bwMWa8kwdBoC_cPw_wcB&redirect=true
Then there is adapters: https://www.amazon.com/TechMatte-Connector-Resistor-Approved-Standard/dp/B0151RKYBG
If you can nit find short cables you might need to cut a longer one down to size and try to splice the wires back together. The other issue is do you still need an OTG type cable for USB-C.
Cheers! Might try the braided cable or this one I just found also - just worried they'll suck all the juice from the phone since it's not a proper OTG?
https://www.amazon.com/gp/product/B0119MWJL0/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A294P4X9EWVXLJ
Some reviews said this worked with the HA-2 but work and work properly are 2 different things.
