thor777
- Apr 9, 2010
Here's my car setup with the burn-in cable courtesy of howdy on one out, and the car stereo aux on the other. Thanks again to ClieOS and howdy!
So what is the best way to control the volume using and iPod classic and touch? Turn the HA-2 volume all the way up and control the volume by the apple device or turn the apple device all the way up and control the volume by the HA-2?
There're actually a lot more options if you look a little bit further east... TaoBao is a China auction site like eBay and there're tons of custom cables for dirt cheap. If you know anyone that can order for you, I think it's much better solution for HA-2..
This is said to be 7N OCC Lightning to USB A which I just ordered (haven't received). They're like $15 each!
http://world.taobao.com/item/521701801173.htm?fromSite=main&spm=a1z09.2.0.0.Qb0kqm&_u=gb030fd0a4d
This is also 7N OCC Micro to Micro (Same seller) that I just ordered as well, it's about $14 each..
http://world.taobao.com/item/45126593073.htm?fromSite=main&spm=5706.1529727.a31f1.3.XKX13w&scm=1007.11502.21311.100200300000003&pvid=9510cd61-fb78-4d78-be6c-38a93b5e505f
And right after I ordered the above, I found this guy with pure silver Micro to Micro for like $20, I like the smaller profile of the housings, thinking if I should just order another...
http://world.taobao.com/item/36777990110.htm?fromSite=main&spm=a312a.7700824.w4004-1184127615.6.JvD9rA
Well, maybe not dirt cheap, but for the materials used and customs, I say they're much better than the ones on eBay...
Does anyone know how the ha-2 compares to the iphone 5 headphone out? I'm looking to primarily use it with iems.
Also, would it work well with the Denon ah-d2000 and HiFiMAN He-400i?
I have ordered the first one, thank you!
I will report back if they are working with iOS or not (as I need the new lightning connector)
The selling shipped mine today, hopefully, I'll get it by Friday and report back But from the reviews, most are pretty happy with the quality.
If you're not using the dac on the oppo, why are you using it hooked up to your car aux input? Isn't that just double amping or maybe even triple amping since your car stereo will amp it too?
Cuz it sounds so much better? lol
Like I mentioned couple pages back, even though the audio is being triple-amped, the quality is much better than if it was coming straight from the AK100ii or the CD player of the car. Try it for yourself if you have a good sounding stack and see if you can tell a difference.
BTW, it's currently running on a '99 Honda Accord with stock stereo and speakers. I've also tested with a '98 Honda CR-V with Pioneer stereo and stock speakers, and '13 Toyota Prius V with stock stereo and speakers. All sound better through my stack.
I have played music through my phone using the HA-2 as a dac and it does sound better than directly out of my phone but you're not using the DAC but are instead just passing analog input through the HA-2 and using the headphone output as a line out. Is it the bass boost that is making the sound better in your setup?
