Thanks! I currrently have the C5D and I am wondering if the HA-2 would be a worth while upgrade for me. Plus, the HA-2 just looks so damn classy.
Mmk, so in terms of features and battery life, the HA-2 is definitely in a whole other league compared to the C5D. Three features that the C5D has that the HA-2 doesn't are 1) the free custom laser etchings, 2) USB Audio Class 1 which does not require drivers to use and might be more compatible with more devices, and 3) user-programmable digital volume potentiometer, although admittedly no one on Head-Fi probably uses this but me, hahaha.
In terms of sound, I think both have their strong points. I tried my best to volume-match the two devices by ear (both devices on low-gain), so it's not a perfect method. I've been using the Audirvana Plus app on OS X for my listening sessions and I wrote some Apple Scripts to quickly switch DACs on the computer while I unplugged/re-plugged the headphone jack into the other device. Headphones used were a beta PM-3 unit (which was meant to be paired with the HA-2), and the AKG K 701 (which I like with the C5D). Music varied between pop, electronic, folk, soul, classical, and jazz; 16/44.1 to 24/96.
Compared to the C5D, the HA-2 does have a kind of harshness somewhere in the lower-treble area that's typical of ESS's Sabre DACs (some say this is the "Sabre glare"). However, I still find the C5D to be a little bright in the upper-midrange compared to the HA-2. Snare drums may not have the harsh/biting sound from the C5D compared to the HA-2, but some upper-midrange sounds do. Personally I prefer the Sabre glare of the HA-2 over the bright upper-mids of the C5D.
In terms of the sense of space, the HA-2 has a more rounded soundstage having more depth compared to the C5D, and also more height. Center imaging seems better on the HA-2 compared to the C5D, which is something I like to see, and that especially pairs well with the K 701. C5D provides a sense of space similar to that of the ODAC/O2 in that the soundstage seems wide, but not very deep. Switching between the HA-2 and C5D, I definitely prefer the more encompassing "music is being played to you" soundstage and imaging of the HA-2 over the more "music being played between my head" soundstage and imaging of the C5D.
That being said, I think the C5D has better instrument separation compared to the HA-2; instruments are more separated from one another and I can better distinguish the instruments in a music track, or there seems to be more black space between instruments.
Another plus for the C5D is that I think it hits bass notes harder and deeper than the HA-2, similar to the ODAC/O2 vs Geek Out oddly enough (bass boost off).
Speaking of the bass though, the HA-2's bass boost is more similar to the C5D's middle bass boost option, but with a little more rumble. Objectively, indeed the HA-2's bass boost is slightly higher than that of the C5D's middle option. I still love the C5D's maximum bass boost for the K 701 though (not so much for the PM-3). : D
But i like to drag and drop files, not adding it to the app itself etc, does the native music player app plays high res audio?
Hm, I don't really understand. You can drag-n-drop music files from your computer into the Onkyo app through iTunes.
No unfortunately the free version of the app doesn't support native audio playback past 16/48 (the regular iDevice limitations). You can still play the high resolution files, and any other FLAC files you have, just that they get downsampled to 44.1 or 48 kHz.
