OhMyGodPancakes
- Oct 11, 2016
Sooo I doubt we'll see an HA-1SE
I don't think it's pointless but you are going to have a difficult time finding one. It's a great amp and I would buy it again regardless if it's discontinued or not.I have a pm1 arriving soon to use with chord mojo. is it pointless a couple of months from now to buy ha1 if its discontinued?
The HA-1 is a step up from the Chord Mojo in sound quality & power, but it takes a revealing headphone to hear any differences. I don't know whether the PM-1 is revealing enough. And even if you could hear any difference, would it be enough to matter? Personal decision.I have a pm1 arriving soon to use with chord mojo. is it pointless a couple of months from now to buy ha1 if its discontinued?
Try turning it off and then move he volume knob fully back and forth about ten times and see if that solves it. May be some particles behind the volume knob bGot an issue where my ha-1's volume is changing by itself. I've taken the battery out of teh remote so it's not that.. Not sure what's going on. Also the right side is alot louder than the left side when i first start it.
Yes. It's a kickass unit. Just make sure you buy a properly working one (if buying used)would it make sense to buy an ha1 if oppo discontinued them? you can still get them in uk. i also took delivery of pm1 today which im using with chord mojo. would ha1 give me any added benefits.
That sounds like an op amp or transistor going bad; a common failure mode is to work only when warm. Your HA-1 probably needs to go back to Oppo to find & replace the bad component. Contact Oppo and find out.Thanks a couple reboots and it seems to be fine. Is there anything we can do with the channel imbalance at the start? It takes about 15 minutes before i can hear the left channel kick in and the channels balance out. At the start the right channel is alot louder than left.
You should email OPPO to let them know. Who knows, maybe it is an easy fix on their end.Just a heads up to anyone who uses the IOS Oppo HA-1 Bluetooth Control app, in case you are not aware this is a 32 bit app. Apple will be releasing IOS11 tomorrow and no 32 bit app will run on IOS 11. If you do upgrade to IOS 11 you will not be able to run this, I am not sure if anyone has reported this to Oppo but I am guessing Oppo don't plan on upgrading this app since it hasn't been upgraded from its original version since it was released in May 2014.
Hey - has anyone changed / upgraded the standard OEM power cable on the HA-1 unit? Any thoughts.....?
I've been looking at something like this fir example...
http://www.custom-hifi-cables.co.uk/home/mainscables/powerblack-mains-cables/powerblack-iec
Cheers,
herbie
