urbino
- May 26, 2012
I would recommend using EAC (http://www.exactaudiocopy.de/) to rip straight from your computer's drive, it is(or used to be?) the gold standard for ripping redbook CDs. I have ripped thousands of my own, and the great thing about EAC is that it confirms the quality of what it rips, way better than having to listen to a rip to see if there are any issues as when "ripping" LPs where there is no other option. If there are issues with your drive, as long as they are correctable EAC will help with that as well. Note that there are a few audio CDs with copy protection, literally only one or two out of the over 5000 I own, so maybe you won't have to deal with this. Depending on how many CDs you have to rip, it may be worth purchasing another DVD-ROM (external USB if you don't have a place to install it internal to the PC being ripped), easy to find a good drive from $20-$40. Just like everything else, this rabbit hole can go a lot deeper though, here is a thread talking a bit about ripping: http://www.computeraudiophile.com/f7-disk-storage-music-library-storage/best-cd-drive-rip-22530/index2.html
Thanks! I was planning to use MC21, but I'll give EAC a try.
