Guys, I tried DSD files but my HA1 shows on its screen PCM 843/32 !
What does that mean? and why it doesn't show DSD?
You mentioned tube amps being better than HA1, if I have the money to get Woo WA22 over the HA1, would you support my decision and why?
I am going to try the bypass to see how much the "pot" colors the sound. J.River volume internal volume uses digital 64-bits via keyboard so it will be interesting to see if I can hear a difference.
I await your conclusions with great interest. Many thanks.
hmmmm, I would never say tube amps are better than the HA-1 or any other SS amp for that matter. It's so a matter of individual tastes, what input devices, headphones, tubes, cables, quality of the recordings, etc are being used. I have only had my HA-1 for a few days. I ran a straight 48 hours playing through my LCD3's for break-in purposes. To my ears, tube amps add a warmer, "colored" sound compared to ss amps, which is simply perfect for the HD800 cans.
I am trying to find a DAC/AMP combo that will allow me to get the most out of my LCD3's, for my ears. I DON't like the sound of my Woo DAC with the WA22 amp when playing through the LCD3's. However, that combo is stellar with my HD800's-absolutely amazing. Thus far, I really like the HA-1 as a headphone amp for my LCD3's, but I am using the stock LCD3 cable right now. Waiting for my adapter cable from Drew at Moon Audio, so I can re-attach my Silver Dragon cable and really get a better idea.
Since I am using headphone out it won't work in bypass so a ran the volume up to max. I then used the J.River internal volume for comparison. Oppo analog sounds better, more analog-like musically.
Some other info:
i settled on the registry value in windows of 16 under Win32 Priority Separation. I also tried Wasapi, kernel streaming, ASIO. ASIO sounds cleaner and more dynamic with less grain compared to the other options.
