Dixter
- Dec 21, 2011
Has anyone tried an ifi iPurifier with their HA1? Does it double up something the HA1 is already doing, or can it actually make an improvement?
if your concerned with noise on the USB line then another solution that I'm using is the Optical USB cable from Corning... it takes the digital at the computer and converts it to optical
then converts it back to digital at the HA-1... no USB power is on the line so no noise is getting through the cable...
google USB 3.Optical Cable by Corning if you are interested...
