ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Mar 18, 2017 at 3:08 AM Post #14,074 of 16,375
Well, technically - Viper4Android will install on a device that isn't rooted, and appear to be running - but it will not actually be processing audio unless it's rooted and SELinux is set to "Permissive Mode".
I've actually got two rooted Google Nexus devices (5 Phone & 7 Tablet (2013)), running Cyanogenmod 13 - and during the update from Viper4Android 2.4 (which worked) to 2.5, both of them stopped processing audio.  V4A runs, but the status for the driver is always "Processinig: No".
Mar 18, 2017 at 7:59 AM Post #14,075 of 16,375
Hi xD
I Have some Questions about "DAmex method" for my XDP-100R....
If I understand this method, we Install a NEW ROM, exactly a Smartphone on Android....
So, Root, de-lock Boatloader, Install Recovery, use ADB, Install ROM.... Oki... xD
But, Where is the Stok ROM for XDP-100r???
So if this ROM bug, or later I don't want ot, where is the STOCK ROM ANDROID 5.1.1 of Pioneer?
So other question, Can I install the Player Stock of Pioneer on my XDP-100r with this new ROM?
Thx.
Mar 18, 2017 at 9:39 AM Post #14,076 of 16,375
I looked at videos on Youtube where people are running it on phones.  Don't know if that matters.  But I am very new at this and am running a ONKYO DP-X1.  Is there something other than the standard interface that produces better sound on the device.  Also, I do not wish to "root" my device, just run it stock.
Mar 18, 2017 at 12:07 PM Post #14,077 of 16,375
​Try working with the EQ and settings.  I didn't like the stock onkyo player at first.  But after I played with the settings, and a lot with the EQ, I now use the stock player.  I use the X1 paired with a creative E5 amp in my car and I absolutely love the X1 it!
Mar 18, 2017 at 12:36 PM Post #14,078 of 16,375
  Hi xD
Thx.
 Courtesy of XVortex, a link to the most recent stock firmware for Onkyo / Pioneer (0.1.37.8_20161104.013642)
https://android.googleapis.com/packages/ota/onkyo_raizin32_raizin32/1295292967f8c11f806630c670f0d2b3e0189588.zip
Mar 18, 2017 at 6:24 PM Post #14,079 of 16,375
I am contemplating on upgrading my aging ibasso DX90 to DP-X1A or DX200.  Really just want balanced out and a decent sound stage. From what I can tell, Onkyo is pretty much the best bang for the buck right now.  Would this be a solid buy for a few years?
Don't have an amp, will be using it with my Ether C's.
Mar 18, 2017 at 8:17 PM Post #14,081 of 16,375
Oh,
I'm fine with the stock player - really like it actually.  Just wasn't sure what all the fuss was about for Viper and some of the other  "adds".
Mar 19, 2017 at 12:13 AM Post #14,082 of 16,375
** SOLVED **
Hi,
Facing an issue with my DP-X1 - looking for some advice from this forum.
I bought the Onkyo DP-X1 about 2 months ago and went ahead and bought a Sandisk Ultra SDXC 128GB microSD card today for expanding storage.
I tried entering it into the microSD card slots in the DP-X1 - however, the card isn't "clicking in". It's just losely entered with about 2-3mm of the microSD card hanging out of the slot. No matter how much I push it in - it's not clicking and staying.
Has anyone else found a similar issue? Any suggestions? Really frustrating :(
Mar 19, 2017 at 12:40 AM Post #14,084 of 16,375
  Hi,
Maybe a stupid question, but did you try inserting it upside down? The card doesn't go in right-side up.
Mar 19, 2017 at 12:44 AM Post #14,085 of 16,375
  Have you carried it in your pocket? You might try an air can and see if there is lint to blow out of the slot.
Hey ... I'm just an absolute dolt of the nth order ... must have drank wayyyyy too much for St Pattys yesterday ...
EElegance triggered me to try a couple of things - and I tried to be more "gentle" with the card as I entered it and it clicked in place ... incredible ... not a lint issue.
Stupidity was short lived thankfully. Thanks for triggering some thoughts and spurring me into motion.
