fezzyness
- Nov 12, 2016
Do you have a balanced cable? What headphones do you have?
i have an hd6xx with a 4pin xlr termination
My understanding is that you would need a Balanced cable, specified as such. The stock cable would not do.
Then on one side you would need a male 2.5 mm connector for the Onkyo, and the 4 pin XLR termination on the 'phones side. I don't know if an adapter would work.
I may be completely wrong with this.
I struggled with finding an inexpensive balanced cable for Onkyo and my HiFiMan HE-400i headphones, until I found one. Having said this, the HIfiman's have a TRRS 2.5 mm connectors, not XLR. So my cable would not work for you.
News: Hong Kong has stock dp-x1a for retail now.
so out of curiosity I called Onkyo USA customer support, and I was told the X1A is same as the X1. Items with an "A" at the end of them usually mean they are not sold in the US or Canada. I told him that made half sense to me, as that would explain why we haven't seen it come to the USA yet, but it wouldn't explain why japan sells both models..
Since I was curious about the Dual DAC / Dual Amp design of the DP-X1, I recently posted a couple of questions on the Onkyo USA Facebook page - https://www.facebook.com/OnkyoUSA/posts/10155743980304689?comment_id=10155754772164689
Here are the questions, and replies -
David Baldock - I've got a technical question about a portable audio device.
In the Onkyo DP-X1 and DP-X1A, are the dual DACs and Dual Amplifier strings used when driving earphones from the Single-ended (3.5mm TRS) output? And, when driving earphones from the Balanced (2.5mm TRRS) output, are the dual DACs and Dual Amplifier strings used, when playing music with apps other than Onkyo Play Music? Thanks!
Onkyo USA - Hello David, when using the Onkyo Music APP both amplifiers and DAC's will be active when using the 2.5 or 3.5 output. We are not sure since we have not tested every third party APP but so far only one DAC is active. Thank you, CB
David Baldock - Thanks for the reply!
When I saw this on the product page -
"The DP-X1 has two amps and two digital/analog convertors which allow for extreme power and signal control. The double ESS Sabre ES9018K2M DACs and double ESS Sabre 9601K amps make balanced output possible via 2.5 mm output."
- I envisioned that one DAC & Amplifier would be for the Left Audio channel, and the other DAC & Amplifier would be for the Right Audio channel.
I know I'm hearing stereo audio when listening to third party Apps. So, as an Electronics Technician, I'm curious about this --- Are both DACs actually operating as Stereo devices, so that either one can send Left & Right Audio to the Dual Amplifiers? Thanks again!
Onkyo USA - Hi David, Both channels go through both amplifiers and DAC's. It is not left to one and right to the other. Thank you, CB
Their reply leads me to believe that it's probably necessary for Apps to be specifically written to take advantage of the Dual architecture.
Take Care,
David Baldock
Which is pretty odd considering fiio is advertising their X5iii as a device that will have dual DACs functioning even in 3rd party apps. Perhaps they encoded it in the android architecture.
Either way, I can't tell the difference, and I'm not sure if that's a good thing.
It would be great if we could get a definitive answer to this question. A trawl through this forum on "are dual dacs/amps used by 3rd party apps" or similar yields many and varied answers. I'm not an audio engineer so I can't answer as to why there is so much confusion.
I am currently trying out neutron - great interface and features. I have tried a lot of A/B comparisons with the Onkyo player and I can't tell the difference. (SE and balanced). Kraftwerks autobahn with neutron electronic music EQ may even sound better
Maybe I should be worried about the functionality of my ears also?
The same. They mean dpx1 has eight capacitors like the dpx1a. But not the same is that dpx1a capacitors are 3 times larger.
