Sadly the blips happen with Tidal on all players. I think it has to be something with Tidal or the way Android reads the files. It is not with all songs so it could be the Tidal file that has an issue
ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
- Thread starter T.R.A.N.C.E.
bobkbusch
- Dec 3, 2014
I've tried adjusting every setting including the digital filter and Lock Range Adjust. Still have the blips...I believe you are correct, that it doesn't occur on every song. In fact, I've just played back the same song 10 times, adjusting one parameter each time, and the blips are still there, but random. I was playing different songs on my first DP-X1 and had no blips. On the few I've tried on my new DP-X1, they are present.
IronFly
- Nov 7, 2016
with the last update, i don't have SD issues (music stops between songs or hiccups) and brightness has the correct setting on the lower one.
bobkbusch
- Dec 3, 2014
Is that with Tidal "HiFi" files played back from your micro SD card? I have the latest update and still have hiccups/glitches...
headwhacker
- Sep 4, 2013
so ive done 500 quid on the unit, 450 on cans and now i am looking at 200 aprox on a balanced cable
im looking at forza and its asking me about a splitter ?
serious head do'er this stuff...
Try amazon as well. You should find something cheaper. I spent a little more on cable because of how well constructed and beautiful the cable was made. The cheapest cable you can find will still do wonders on DP-X1 when balanced.
I have the AK-320 and can't really tell much difference between it's balanced and unbalanced output except when I used iAK's s own external amp. But then I find the balanced output of DP-X1 better than AK320 (any output including the amp). All my iems sound very clear, energetic and well-controlled on DP-X1 balanced.
phthora
Check these out: https://www.surfcables.com/collections/cables/products/sony-mdr-z7
$105 bucks. Surf Cables is a respected brand with some of the more reasonable prices across the board. I plan on picking up some IEM cables for my Shures from them.
Jamie101
- Dec 2, 2016
thanks again for tips , i like the black braided forza so may give them a bell and get one , making sure it's the right one as im bound to order the wrong one,
thanks a lot, back to listening to my beloved autechre aphex twin and snd, not too soon!
I have 2 cables from him. Just make sure when ordering to tell him (in the note section)your exact setup as that helps him.
IronFly
- Nov 7, 2016
Nope, stock onkyo player
huyendep
- Sep 29, 2016
Thank you. I've just ordered one for my IEMs. Waiting to try the balanced of this player.
loungecat
Hi Guys.
Enjoying my Onkyo dap very much, unfortunately all my earphones have 3.5mm jacks.Would love to hear the benefits of the balanced side of the DP-X1 with the 2.5 mm Input.
Is my only option,to buy new Headphones ? and then purchase an after market lead with MMCX connector?
Apologies if it's in the wrong thread, Can anyone recommend ,a reasonably budget pair of in ears, is my preference.
I don't think or know any other option really,hoping someone will
Regards Steve.
Regards Steve.
DBaldock9
Hi Guys.
Regards Steve.
I do prefer to connect my earphones to the balanced output on the DP-X1.
Do all of your current Headphones / Earphones have tethered cables?
For removable cables, there are several stores on AliExpress that sell balanced replacement cables, with different styles of connectors at the earphone end.
If you don't mind a bit of a wait (because he's so busy right now), you can also order custom cables from Lindsay at ImpactAudioCables - https://www.etsy.com/shop/ImpactAudioCables
If you need to buy new earphones with removable cables, there are a couple of threads you could refer to, for budget models -
http://www.head-fi.org/t/805930/best-sub-100-chinese-brands-earphones-thread-hidden-gems-personal-favorite-best-deals-and-impressions-sharing-for-audiophile-on-budget-include-best-chinese-headphones-dap-section
http://www.head-fi.org/t/820747/chinese-asian-brand-info-thread-portable-headphones-and-iems
Take Care,
David Baldock
loungecat
Take Care,
David Baldock
Cheers for your response David ,will have a look a bit later
Just got a DPX1A firmware update 0.1.37.8
The update contains the following changes:
1. Enhanced Android system security.
2. Enhanced read SD card stability.
3. Enhanced the LCD panel brightness adjustment.
4. Added the new item in “Gain setting”.
Remark: “Low” is default setting, however “High” is default setting after firmware updated, please beware of the volume.
This is a 723.6 MB download and Onkyo's server is pretty slow... It wil take a while
Total: 13 (members: 0, guests: 13)
