unknownguardian
- Sep 7, 2013
there are rumors saying the dp-x1 successor that i posted above might be a smartphone. well do notice that there's a hearing bar on it which is usually found on phone.
That could be the 'normal' audio speaker as well, which the DP-X1 didn't have, however there are 2 holes in the bottom, one of them could be a microphone?
Will be the first smartphone with a balanced headphone then I assume.
If this new device is a mobile phone, I will be willing to pay almost anything for it. Fantastic device and the ability to nit have to carry anything else?!? Awesome.
fastboot -i 0x0746 devices
fastboot -i 0x0746 oem device-info
(bootloader) Device unlocked: false
fastboot -i 0x0746 oem unlock-go
fastboot -i 0x0746 boot twrp-3.0.2-0-Rai_Zin_32.img
fastboot -i 0x0746 flash recovery twrp-3.0.2-0-Rai_Zin_32.img
I love the A800, but I never was able to use it with the DP-X1 as mine was sold. I think you were asking about that is this correct?
Great.
Yep, in the very same context.Don't like those art deco looks, though.![]()
Too many flagship headphone releases these days. I gotta keep an open mind.
here is how to about unlocking your onkyo dp-x1. compiled twrp for our device and here is the guide.
prerequisites - fastboot + fastboot drivers for onkyo dp-x1.
okay, so here we go:
turn off your device.
turn it on holding backward and power buttons
connect it to pc.
in command line do
and then you will see your device connected.
next thing - we verify that bootleader unlocked or not
pay attention to
if it is false - unlock your bootloader by
here is twrp 3.0.2-0 recovery:
https://drive.google.com/file/d/0B9WN-DrZ4uGTa2tCNzRJNHROTmM/view?usp=sharing
md5:
https://drive.google.com/file/d/0B9WN-DrZ4uGTMGJmUmtKTHdwaUU/view?usp=sharing
while you're at the bootloader, you can try to boot to your new twrp recovery by doing
if it is booting and working for you, you can replace stock recovery with it by flashing it from fastboot bootloader by
or by flashing image through twrp itself (available through menu)
WANT ROOT?
Flash SuperSU:
http://download.chainfire.eu/supersu-stable
Is anybody else having issues with the DP-X1 and Apple Music?
On my DP-X1 in Apple Music I cannot add songs to Playlists and also not download more than about 200 songs at once (otherwise download freezes).
I completely reinstalled Android and also Apple Music several times - but the issue just does not disappear.
Also, I have checked a friend`s Android phone if he has the same issue - he did not!
So it must be the DP-X1 firmware I guess?
Any ideas or experiences?
Thanks!
