scotty59
- Sep 27, 2014
Make sure you are trying to download from the link in XVortex`s original post and NOT from one of the links in the quoted posts.
You are absolutely right. Thanks a lot.
Have always had good experiences with Onkyo in the past, which is one reason I decided to buy this product. However, from what I'm reading here, this appears to be a very "buggy" Beta-style device. Hope I'm wrong.
Well done and thank you.
Is this completely reversible/uninstallable?
OK. Here is the custom TWRP recovery for Onkyo DP-X1 DAP: link
If you do not know what it is, then you do not need itUse at your own risk.
Brief instruction:
1) Boot your player in Fastboot mode (press Power button + Prev track button simultaneously until the penguin)
2) Connect to USB, Install the driver if necessary (Choose "Android ADB interface" from the drivers list).
3) run _flash.bat file or use manual commands to flash or boot into recovery.
You're done. Enjoy!
Whenever I press the button combo it takes me to recovery instead. Plus the bat file says
If you have never connected to ADB before, you may want to a quick few things:
1. Boot into the DP-X1 as normal.
2. Go to device information in the settings app
3. Click on the build number 7 times to become a developer.
4. Open up the developer options menu that appears in the root settings menu.
5. Enable USB debugging.
6. Attempt to connect to the device over ADB.
7. You should be prompted if you want to trust this computer. Select yes, and make sure you click the checkbox that says "always trust this computer".
8. Type "adb shell" to get an ADB shell.
9. Type "exit" and then "enter".
10. Turn the device off
11. Turn it on by pressing and holding "power" + "prev track".
12. When the penguin logo appears, wait 20 seconds.
13. Try the "fastboot oem device-info" line and see if it returns anything.
It's a little bit different on a Mac. No need to install drivers, although you have to download Android Studio to get adb and fastboot. But I've had no issues, and have flashed it several times.
Really, though, I don't recommend installing this just to have it installed. It doesn't get you anything. It's not like we currently have custom ROMs. It's only a helpful little tool if you are a developer or if you manage to royally screw your device and you need to fix the software. There are also still some bugs that will probably need to be worked out, and it doesn't support encrypted devices at the moment. Wait until we have some packages that we can install. This would allow us to root without Kingroot, but nobody has yet written up a guide for that, so it's not too useful.
In other news, it looks like the Onkyo engineers are now aware of the distortion issue in 3rd party apps and are working to fix it.
http://forums.onkyousa.com/viewtopic.php?f=9&t=9368
You know ? Such bugs and issues like this should have been taken care of by Beta users, testers, reviewers....but too bad, Onkyo didn't take it that serious
