XVortex
- Jan 19, 2016
Two developers
Porting the TWRP for DP-X1 is almost done. I'll be ready in couple of days:
Sorry, got busy.
Here's part two of @hansgw crazy monster DP-X1 storage on steroids (part 1 link here!):
Ha ha, nice on first Orpheus HE90 choice
If you want to connect DP-X1 to Stax/any electrostatic headphone, there is a way...
The iFi Audio Pro iCan is a great upcoming amp with huge number of inputs and outputs, but eventually you can buy an iFi Audio Electrostatic Headphone Energiser add-on for the Pro iCan.
All you will need then is a 2.5 mm TRRS to dual 3-Pin XLR interconnect cable to connect DP-X1 to Pro iCan, get that energiser add-on when it's out, and then connect electrostatic headphones!
Sources:
You're welcome <3
Yes, I like first Orpheus much more than new one. New one reminds me .... kitchen tool with lot of spices bottles
Done... X1 - SRM-T1 (tubes) - Stax Lambda Signature ...... Just one comment - went to bed only at 3 (morning). Feeling like after hot night with Monica Bellucci
Ifi - looks nice, but I do not believe in small and light amplifiers for electrostatic headphones. By my opinion Stax MUST be amplified by tubes (retrograde again
Ha ha ha, a TOTL spice box! I can see that now; lmao!
So, you had a good night, eh? He he he
Erm, some points:
The iFi Audio Pro iCan is very, very light, to the point where this has been considered a criticism.
The reviews posted in my post indicate that plugging in cables (input or output) will move the amplifier.
iFi Audio Pro iCan has NOS General Electric 5690 vacuum tubes, but the amp can be used in various modes:
- Solid-state only via J-FET and MOS-FET transistors
- Hybrid of J-FET, MOS-FET and NOS GE 5690 tubes WITH maximum feedback
- Hybrid of J-FET, MOS-FET and NOS GE 5690 tubes WITHOUT feedback
Also, the Pro iCan is overall very compact compared to the competition, especially when we consider power output (4.8W unbalanced, 14W balanced!).
However, without the iFi Audio Electrostatic Headphone Energiser module, I cannot say how much room the entire system may take up/require.
I talked to a online store in UK since is on their site, but they claim is not avaible in UK even is on their site
they say there is technical issues with Onkyo DP-X1 can someone verify this
This is the email i got from the store
So this is the reason why i cant find Onkyo DP-X1 almost anywhere in europe
@bluedolphin, I have covered this in my post above and in an earlier post, but I'll try and be more clear.
The original issue was hardware/QC, as failure rates were very high for original Japanese Onkyo DP-X1 batches.
On those older units, there was an issue of plastic jack housings cracking or breaking in either 3.5 mm or 2.5 mm outputs (predominantly the latter). The original design had weak plastic.
This issue has, according to Onkyo UK, been resolved.
The wait for new stock in all international territories was due to this issue being fixed first.
Onkyo EU and UK (and to a lesser degree US) are going to receive new units of re-manufactured Onkyo DP-X1.
The lesser degree for US is because they have received the stronger units already.
The first international territory to have received the new units was the US. They should have had stock of these from last month.
The time frame of for the EU and UK is at the end of June 2016 (this month).
Please remember, only official distributors are getting the new units first in all territories.
Thus, no international, officially authorised Onkyo distributor will have stock of thee new units in the EU or UK at present, or before.
I would wait for the stock of new units to arrive before trying to secure any unit in the EU or UK.
I am sorry if this is not directly related to DPX1, but do you know if this also fixes the jack issues which i read in the pioneer XDP100R forum?
Update from my side with my Japanese DP-X1 unit:
Ordered on Nov 2015, shipped out Jan 2016 via PriceJapan.
I had initially thought it was just the angled 3.5mm trs Neutrik plug that came with my ciems that wasn't up to spec, since it would unplug itself by the tiniest of movement and cause play pause as it detected headphones plug removal automatically. I had posted about this issue with photo deep in this thread.
Well turns out it happened again with another angled 3.5mm TRS plug of another cable, this the big tankish oyaide one. But I had again dismissed it and pinned it against the angled type plug which more easily makes rotation movement due to the cable angle. Because when I was using the tiny straight stock Noble cable I didn't get any issue, and also with the small factor angled plug of the Fiio EX-1, it worked fine without any unwanted pausing...
Well now it's been the 3rd week now that I can't use the EX-1 with the DP-X1 because it now too unplug itself all the time and way to fast. Within seconds of putting it in a pocket I start to get small snappy tick sounds while music plays because of connection movement and within a moment later the doomed auto pause because it unplugged itself 1mm which is enough for the player to detect it causing headphone disconnection...
My dilemma now is that I only have the 2.5mms TRRS jack that works flawlessly -for the time being- with the Eidolic straight spacious barrel which sits flush against the DP-X1 and doesn't move and is gripped nicely inside.
My fear is that I'll start to get the same issue with my balanced output sooner or later. And even if it never happens I basically have a devalued unit as I can't expect to resell it in the future if the main 3.5mm TRS output is not working well.
I'm inclined to ship it back on my expense to pricejapan while I still have 5 months of local warranty. Trouble is, I don't know if Kaneda-San recovered or not.
Edit: I also tried each cable with my other dap, the Cowon plenue d which thankfully works perfectly (knock on wood)
