ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Jun 10, 2016 at 4:15 PM Post #9,123 of 16,328
Its kinda weird to me that aren't using the same music app instead of spreading patches and updates to two. Since essentially both daps are made by the same company. The only big question I have always had is if using these third party apps still utilize the dual dacs.
Jun 10, 2016 at 5:51 PM Post #9,124 of 16,328
Tried the Pioneer apk
Personally not for me, different but not better for my uses
Jun 11, 2016 at 12:59 PM Post #9,126 of 16,328
Feeling like an idiot but where exactly is the pioneer apk/music player? Searched the play store but apps seem to be for controlling pioneer products like blue ray players etc. Exact name of app and where to find it?
You can find the information here:
http://www.head-fi.org/t/780642/onkyo-dp-x1-dual-sabre-dacs-balanced-sabre-btl-amp-mqa-dsd-256-android-5/9015#post_12634677
Download the APK file, copy and paste it into device, and run the APK (works like an .exe in Windows) which installs the app to the device.
Jun 11, 2016 at 2:05 PM Post #9,128 of 16,328
Many thanks for the link. Paste into the root folder?
Jun 11, 2016 at 3:24 PM Post #9,129 of 16,328
Have you rooted your device? If so, do the af.resampler.quality=4 build.prop change? This has virtually eliminated the horrible static for me in 3rd party apps.
-Dirk
Was too scared to root it due to potentially not being able to update it. But I've already returned mine sorry. I'm sure the issues will be resolved soon though. Especially since a lot of people are posting on onkyos forums now.
Jun 12, 2016 at 12:33 AM Post #9,134 of 16,328
-Dirk
Hi Dirk
Like others I get no sound on third party apps when changing the build prop.
Would you be able to give a detailed run down of how you rooted and what you used to edit the file, etc?
Maybe you have done an extra step that is crucial?
Jun 12, 2016 at 1:07 AM Post #9,135 of 16,328
I went to a trade show yesterday and tried the following:
Good result when listen to dp-x1 3.5 port:
UE 18pro
Heir 10a
Jomo 3
Audeze EL8 closed
Not too good results:
akg k3003
Average result:
Weston es60
