addyg
- Feb 3, 2016
I doubt that.
This device drives my 8 BA Angie without any problem.
I suspect it's a jack connection problem.
Yes, that is one possibility. But try 2 - 3 iem should confirm it.
I doubt that.
@addyg I find you continued asking of other members to not write there opinions very insulting and for that matter I have reported you to a moderator. I agree with other members that the fact that there are so many issues with a 700 dlls dap is inexcusable on onkyos part, and even do you continue to defend onkyo and his product in a fan boy matter I think others have been respectful of you comments
I'm using SanDisk Ultra 200 GB and 64 GB cards. I imagine this is a general SD card reading problem on the DP-X1 but has anyone found a particular SD card that doesn't stutter all the time with Tidal offline?
I've extracted Music app from both Onkyo DP-X1 and Pioneer XDP-100R DAP's.
You can install and have both apps on X1, compare and use what You want:
com.opi.onkyo.dap_music.apk
com.opi.pioneer.dap_music.apk
I believe you are correct in that it is an SD card read problem at the root of this issue.
Have you updated your Tidal app to the latest version? Whether by accident or design, this update significantly reduces the glitch/stutter problem. It's not completely eliminated but much more brief and infrequent.
Hope now turns to Spotify fixing the offline storage to SD card that they broke in their last update. Although that's also an Onkyo issue to some extent as it still works correctly on my smartphone.
I don't think the SD cards are the problem to be honest. I stream from Tidal (which is downloaded to the internal storage, no SD card in the equation) and it has audible distortion and hiss. Especially noticeable when putting the volume down to around 5 or so. Someone did mention that third party apps like Tidal use the dual dac right? Is this confirmed? Cause my first guess would be the noise is caused from not using the 2 dacs like the default music player and its actually using the snapdragon dac which I could see causing some distortion especially when you consider how they separated the two PCB's.
