Peridot
- Jan 25, 2009
So Onkyo have inflicted us with a crap 2.5mm connector on the DP-X1 and they aren't even providing a 2.5mm cable with their new range of headphones
So Onkyo have inflicted us with a crap 2.5mm connector on the DP-X1 and they aren't even providing a 2.5mm cable with their new range of headphones![]()
Did yours break to? I have not even tried mine in Balanced yet. If mine does break I will just send it in for warranty as I really do like this player overall. Hopefully they will step up and find a solution, and they should extend the warranty for the 2.5mm socket.
2.5 TRRS on the dp-x1 gotta be specially made
Whitigir may have been referring to the need to have 2.5mm cables specially made for the Onkyo 'phones.
AFAIK all 2.5mm TRRS implementations have been the same so cables are interchangeable between devices.
What difference can one expect in SQ from a single ESS SABRE 9018 DAC and the Onkyo's DUAL ESS SABRE 9018 DACs?
As long as they are balanced headphones and you have a 2.5mm termination they will workcan I connect headphones to balanced out and how it usually works?
The dignis case is 110 SGD including shipping, is it worth it?
None, certainly not audible. Now to add to this comment, the idea that the balanced design yields a difference isn't what I'm talking about, but that would be due to more power not the extra DAC chip, and possibly a little cleaner power with ACG (although I'm really not sure the noise floor was ever audible anyway even in SE).
Glad you edited that as I was going to suggest the original short post was factually correct but potentially misleading (although the OP you were responding to was far from clear either).
I believe it is the additional power, and to a lesser extent the additional channel separation, that makes the difference with the balanced output on the DP-X1.
I still don't fully understand how AGC works but in situations like this I trust to my subconscious mind and I find myself drawn to this mode, rather than full balanced, on headphones where the additional power is not needed. Whether I could positively identify the difference in a volume-matched ABX test I'm not certain.
