NPWS
- Dec 1, 2015
Just bought this and the E900M today - there is no option for the E900M in the Music Application on the DP-X1 : (
how much that cost? where do you buy it?
thanks
thanks
PC dac is not a practical thing for dap to do.
Can I ask do you have a 2.5mm TRRS for your IEM's
Because if you are enjoying your DP-X1 SE you are in for a treat if you ever go down the path of Balanced/ACG
Anyone know that is the DPX1 3.5 output is same with the XDP100R 3.5?
Since I don't have enough budget for a player and balance cable now, I am considering to buy the 100R instead of the dpx1. Or buying dpx1 and wait for the balance cable?
Any suggestions? Thanks!
Buy the better one. Then buy the accessory. Repeat.
I have ordered a DP-x1 from PriceJapan and it will be shipped tomorrow. However the case is back ordered and won't be shipped for another month. I've looked at the Dignis case and was wondering what the experience has been regarding shipping from Dignis.
Fast. Within a week in my case.
Thanks. Ordered today so hopefully DP-X1 and case arrive around the same time. I live in Mexico and am traveling to Vancouver Canada for a month and have lots of new stuff coming to my sons place to try including some 64 audio U12s, the Onkyo and cables etc. looking forward to the new gear.
Yes they are the same. You may even use dp-x1 default player Music.
So you can then also use the Pioneer music app on Onkyo? I suspect they are quite alike, except for the cosmetics anyway.
Single ended they both should sound the same, or so similar to be inconsequential.
