Hi all,
Results of my Onkyo test are unfortunately not positive. My main reason for wanting this DAP was the streaming, as my main DAP is a Lotoo PG and I am super happy with it.
As was mentioned before, all 3rd party apps I tried including Tidal, Spotify, Neutron player etc. had noise which was unacceptable for me. This noise is very easy to identify as it stays constant with no relation to the volume setting. So set your volume to 1 and play something with Spotify and you will hear it if it is there.
If looking at just High-Res playback of files, it is a very good DAP for the money. Every function worked well and quickly, I liked the UI and SQ. Oh, and there was a problem with the folder browsing, any file opened through that tab would shut down the Music Player app. I didn't try to fix this, just kept using the other tabs so it may be unique to the player I had.
Hope this helps some one.
