masterpfa
- Dec 30, 2014
You means I can use the folder play? Thanks
Yes folder play is available
Just update the 'Music' player in the Google Play Store
Really fancy that red one; it wasn't available when I ordered mine.
The price increase rules it out though, it was already expensive
Hi! Just bought a dp-x1 and realized the eq does not work at all! Whatever setting I use, it does not have any effect on the sound! I am wondering if this is could only be a software issue? Because everything else work fine? Could it have to do with that I use Dodol launcher to change the os design? Any ideas? Thanks!
Honestly the time I spent with DP-X1, I could tell that EQ scaling wasn't it strong point
Why would the EQ make much of a difference? I would think the headphone has more to do with the results than the EQ unless the EQ was so poorly written, and is that even realistic with the Onkyo? What information do you have on the EQ built into the DP-X1? What design parameters cause it to be poor?
It is not exactly poor, but like I said, it doesn't "Scale" too well. You know ? Just kind of when you adjust the EQ, the effects are not really noticeable compare to the devices that "scale" well with EQ. I don't even know how to explain it to you. But there are 2 types of players regarding EQ: 1 that scales very well with EQ, and 1 that doesn't really scale too well.
Comparing both DP-X1 and ZX2 on the same TH900, there were distinctive differences on EQ scaling, and ZX2 proved a better device in EQ scaling
I agree that the eq doesnt scale well on the Onkyo. For me if I try to increase the bass it starts to clip. Correct me if Im wrong, but is it because there is little digital headroom the way the Onkyo processes the digital data?
Does it do this equally you find for various headphones? I'm sure there can be issues with a software EQ, but it would be really interesting to know for instance how the EQ is implemented differently with say the ZX2 as compared with the DP-X1. My only point in mentioning this is that it does take a moderate amount of effort to be sure it is the EQ and not the headphone in some cases. I'm actually not contesting the point that an EQ can be less than optimally implemented, I am however questioning the proof that is sometimes offered to support the claim.
Yes, it does it equally on the headphones that I have tried - hd650, th900, ie80s. It isn't the headphone, it is the EQ. I have the Cowon S9 and P1 which have very good scaling.. I can get very high bass levels on my headphones with the Cowon players without any distortion. I don't know if it is a hardware limitation or the Onkyo's factory app, but they have little digital headroom or I guess it can be called dynamic range before the eq starts clipping.
