Sonic Defender
Here's what I have found comparing My LG G4 that has a Snapdragon 808 with DP-X1. While playing Depeche Mode' Policy of Truth in 5.6 MHz DSD using Onkyo HF player, all six cores were active and the CPU use was around 18%. Playing the same file on DP-X1, only core 1 and 4 were active in both SE and balanced mode, with CPU use around 30%. It looks like something is doing the work of decoding that 1.2GB song on the DAP since 2 cores don't bother waking up
I have used CPU-Z to monitor CPU use.
That seems conflicting, forgive if I'm missing the obvious. So if all four cores on the LG are working, but the CPU use was 18%, but the CPU was used more on the DP-X1 (30%), even if it is only two cores, doesn't that support at least some of the processing for the HF Player happening on the CPU?
Edit: unless the relative strength difference between the CPUs was such that 30% on the 801 is essentially equivalent to 18% 0n the 808.
