- Oct 8, 2010
Heads up, I just got an OTA, I'll give some screenshot once it is done.
UPDATE:
My parcel is at a local Post Office, and I've been charged.
Oh well, never mind.
I'll pick it up in about 8 hours or so from now (01:23 GMT atm).
I just got this update 20 minutes ago, it's about 690~MB, haven't read patch notes yet
Tried rummaging through Onkyo's Japan site, the patch note is still on the 1.25.4 version.
Unfortunately, 3rd party players lack this bit of code, and thus are unable to interface well with this audio circuit - hence the distortion you might hear.
Take LG V10 as another example, third party apps are unable to make use of its 'HiFi mode" which switches over to use their ESS DAC over the default dac.
Is this from pricejapan to uk?
How much was the damage?
The 32 ohm, you mean T5p, right? T1 is 600 ohm I'm pretty sure.
To those who have their DP-X1, how many of you use USB audio player pro and how does that work for you?
https://play.google.com/store/apps/details?id=com.extreamsd.usbaudioplayerpro
The open question is how much Onkyo has customized their android, in terms of making sure the DAC is used for any audio app used. Frankly if they haven't, it's a big oversight on their part. Maybe it's the other way around though, the 3rd party being written to speficially for CPU use as underlined by some people as soon as the app wants to EQ, DSP or touch the sound then it needs to use the CPU unless it has been written specifically for a given DAP which is unlikely for now. I do think streaming services app do not fall into that category and use the DAC.
If someone at XDA or a skilled android dev was willing to look into the DP-X1 code we would know for sure...
Also, for a dev to properly look into the code, it's not that easy. Onkyo has not released open sources for the DP-X1 (nor may they be planning to- it is quite likely that they will keep it closed source as it contains propriety technology like their ACG mode.) You can't look into closed-source code - not easily at least.
Root a device and everything is possible, but even without that you have apps like Root Explorer, that's not an issue.
