rushofblood
Just a bit off topic, did your zx2 have over 300 hours of burnt-in?
For sure, at least like 700 hours by the time I sold it.
PS. The pre-installed screen protector has the stupid "Protection Sheet" marking on it which is an absolute eyesore...
Have you tried seeing if there is an actual screen protector under the 'protection sheet'?
There isn't; it peels off to reveal bare glass. The official glass screen protector is fantastic, though. Very high quality with slight rounded edges.
Did you run comparison's on the zx2 through the TRRS outputs?
1. Go to Settings > Audio > Equalizer.
2. Make sure that "Use GMMP EQ" and "Use External DSP" are both ticked. (Note that not ticking "Use GMMP EQ", will force GMMP to use the stock Android DSP instead of AudioFX. You must instead disable the GoneMad EQ separately as described below)
3. Exit settings and go back to the main app front end.
4. Click the three horizontal lines icon in the left corner of the app
5. Go to "Effects" and disable "Equalizer".
6. Finally, open up AudioFX and make sure it's enabled. You should be ready to rock n roll now.
Anyone able to give GoneMad Music Player a try? If it plays nicely with the dual Sabre dacs and Onkyo's volume levels, it may be an ideal alternative for users who aren't satisfied with the Onkyo player's media management capabilities. GoneMad has the best media management I can find on Android. It actually lets you browse by "Album Artist", has a nice UI and is very customizable.
Here are the instructions I made to enable GMMP to use CyanogenMod's AudioFX (MaxxAudio) DSP (rather than GMMP's own DSP or the Android stock DSP). Possibly the settings (one way or the other) will have an effect on the DP-X1 as well.
http://www.fujiya-avic.jp/products/detail95205.html this one ?
Asked Dopaminer if he could get me oneNow to wait for an elegant Digni leather case to be released
Your posts today were good news! I'm not as eager as Gearofwar but slowly going that way
hey guys,
i am having plans to get this dap. but will it be of any use to me if i don't intend to take my music collection beyond 320kbps mp3? taking only sq into consideration?
i currently own fiio x3ii and shure se846.
@varunaravind92 This can actually compete with AK240 on its own for this kind of price, X3ii is like low-mid end solution, not to sound snobbish but it is quite a step up.
But at normal listening levels, no hi-end player has any advantage over any low-end player. It is all down to personal preference.
