cobrabucket
Would rooting it help in extending battery life? Also, am I correct in assuming that this does NOT support sacd ISOs? DSF only?
Sweet! How's this thing pair with BGVP DM6's?
I have my DP-X1 paired with the BGVP DM6 and the sound is amazing .. I have bunch of DSD files as well as FLACs and for the kind of music I listen to (Rock, Hip-Hop, Pop), it sounds really good. I have now switched to using a balanced 2.5mm cable with the DM6 and the sound is taken to another level. Definitely try the balanced option if you can.Sweet! How's this thing pair with BGVP DM6's?
Also, DSD is converted to PCM before coming out the 2.5mm jack correct? Even if a usb app [like Hiby Player] is used? How about if I feed something like a Fiio Q1m2 a signal through usb? Still DoP? I'm hoping there is a workaround to output native DSD via the balanced jack...
The only thing that can come out of the 2.5mm TRRS or 3.5mm TRS jacks, is analog audio, that has been converted from digital by the two DAC chips.
You can use the stock Onkyo Music Player, or other apps, like UAPP, to output digital audio via the USB port.
I am guessing this is being sent via DoP [converted to 24/192 PCM]? You say it sounds amazing, so that's good! Do you use the option to upsample everything to DSD? Saw a review mentioning that feature and it said it sounded great. I have heard DoP in the past and thought it sounded very good, but was still missing that warmer "something special" sound that native DSD had.I have my DP-X1 paired with the BGVP DM6 and the sound is amazing .. I have bunch of DSD files as well as FLACs and for the kind of music I listen to (Rock, Hip-Hop, Pop), it sounds really good. I have now switched to using a balanced 2.5mm cable with the DM6 and the sound is taken to another level. Definitely try the balanced option if you can.
Is there any advantage of using the $8 UAPP over the included Onkyo Music Player? UAPP works with the TIDAL service better than the TIDAL app? [I thought the TIDAL mobile app couldn't do "Master" MQA level audio? UAPP can?] Looks like something I might have to buy, seeing as it could be a way to deliver native DSD via usb...Merry Christmas! UAPP now with more Tidal MQA
I get 12-14 hours all the time even after all these years of ownership.I have been trying to read some of the older posts in this thread. Some caused me to expect poor battery life, so I was pleasantly surprised to get 17 hours from last night to today burning in a new pair of 300 ohm earbuds. Starting from a full charge I listened for a couple of hours before bed last night which took it to 90%.
I left it playing while I slept and when I got up it was at 40%. I continued to let it play through the day and finally after 17 hours it was down to 10%. I shut it down and plugged it in. Waiting to see how long it takes to get back to a full charge. So, 17 hours driving 300 ohm buds with high gain, single ended, about 128 volume. I am surprised by that volume setting as I am not a high volume listener at all.
Edited to add - I have been keeping it in airplane mode. I really only need this as a pure music player and I like the stock player.
Later when it is charged I will listen with my Nighthawks through the balanced output. I assume battery life will be less using it balanced.
My big worry is still about the headphone sockets. I am kind of frightened when pulling out the cable. I don't want to send it back because it is really nice but I will be very upset if the sockets break. I almost wish that I did not know about this.
