shane55
- Apr 5, 2010
So... any consensus on whether or not the new firmware affects sound quality... plus or minus?
Cheers
Cheers
Same quality, no changes.So... any consensus on whether or not the new firmware affects sound quality... plus or minus?
Cheers
The sync problem get solved by itself, after three hours the synchronization finished, it seems the problem was some corrupted flac files in the internal memory. During this three hours the only thing I can do is wait for the miracle because there's no other options. You can't flash the firmware with the PC because Pioneer don't let you the drivers nor software to do it. In the manual said that by pushing power button for more than 10 seconds you can turn off the player in a malfunction case but when you turn it on the first thing the IU do is sync the library and the problem starts again and again. I do not comment the solution here because NOBODY give an answer or idea for help with my issue, so I assume nobody matters that problem (I recognize is not usual to put corrupted files on internal memory but it could happens) but I give you all a free advise: TURN OFF THE AUTOMATIC SYNCHRONIZATION because if the internal memory have some problem (let say damaged sectors for example) your player is going to be stuck in sync process for a loooooooong time and you can do nothing because the auto sync is the first process to be started when you turn on the player.Second that
About the second reply the new firmware sounds exactly the same the latest one. I can't find any difference in SQ ( to be honest I can't find any difference even in the UI but the new Bluetooth option to allow or not the Android app connect). that's all folks.
Oh! Remember that downgrade the firm is an imposible mission so if your player works well let it be.
If it's the US version it should.Anyone know if this one allows Tidal streaming in the U.S.?
https://www.newegg.com/Product/Product.aspx?Item=9SIA3JX5S28611
Sounds like a euphemism lol.I’m patiently waiting for USB out functionality to return. My Mojo is strapped to my DP-S1 in anticipation ...
