mp3
- Sep 20, 2008
Is there any replay-gain settings, or can it read the RG info from files?
Mine is from Amazon Japan and no Tidal too. Only tunein and radiko.jp.
It does not allow to use as transport mode too (no USB audio out)
My XDP-30R arrived today and I have the same problem (no Tidal). I will try to update its firmware from SD card in the evening.
I tried that too.. its grayed out because it has the latest firmware..Let me know if you can update the firmware manually from sd card. I have been updating it always from OTA for the previous firmware versions.
I tried to download the firmware from pioneer EU website again yesterday by sd card and I am not able to do so as the update selection is always greyed out
Wonder is it because it can only upgrade to a later firmware from existing.
That sucks. Did y'all contact Onkyo/Pioneer about the issue? It's especially dumb since it's an advertised feature.
USB audio out is currently working.
I listen to my DP-S1 everyday at home stacked with a iFi micro iDSD Black Label.
Have the DAP off and connected to a powered amp/DAC. Turn on DAP, play a song, select three dots to right of song, select the top left option with play triangle and sound waves, select USB audio out.
That could sadly explain it. My DP-S1 was sold to me from someone in Hong Kong. It has working USB audio out and Tidal.
It's surprising that the same player in different regions would have such software disparity.
I am not sure about "bit to bit" but for sample rate to mojo, the DSD white light is on when playing DSD files (white light on mojo means it's DSD input), for up-sampled flac/wav 192K it does light up correct bluenissh-purple, others are red 44.1. All DSD can't use EQ. Hope this answered ur question.Can you check if USB audio out feature is bit-to-bit perfect transfer to external DAC? Mines doesn't look like it is.
Mines also get white light on when playing dsd file, but it shows that the file is upsampled when playing with my mojo (click 3dot icon and the sampling rate will be shown), the flac files will unsampleI am not sure about "bit to bit" but for sample rate to mojo, the DSD white light is on when playing DSD files (white light on mojo means it's DSD input), for up-sampled flac/wav 192K it does light up correct bluenissh-purple, others are red 44.1. All DSD can't use EQ. Hope this answered ur question.
