Nimweth
I am interested in getting a good DAP with a balanced output. What would you guys recommend for under 200 GBP? I would like Bluetooth, line out and buttons rather than touchscreen. Thanks
Xduoo X20? Under 200 GBP, Bluetooth, balanced, line out and buttons based control.I am interested in getting a good DAP with a balanced output. What would you guys recommend for under 200 GBP? I would like Bluetooth, line out and buttons rather than touchscreen. Thanks
I think the "PRO" model of the R3 is coming out very soon for the same price. Might be worth waiting/looking for that instead. Supposed to have better battery life and sound quality.
Thank you! That looks just what I'm looking for!Xduoo X20? Under 200 GBP, Bluetooth, balanced, line out and buttons based control.
Thank you for that, it is a touchscreen model, though!
Hiby R3 is a good bet for sure.
Sorry for late reply. I managed to get it fixed (for now). I re-formatted the card using my Samsung S9 phone and i now belive its in exFAT and no problems yet, fingers crossed. I was under the impression the Acmee MF-01 only accepted FAT32...Does the math add up on your card? If you look at the contents on a computer, can you see these files? Is this card questionable?
What does your computer say that these files are? They seem consistent.
My exfat cards work in my phone and daps
All my card are formatted exFAT and work on Android phones as well as DAPsIt does work in DAPs, but I've never seen a possibility to format a SD as exFat on the internal slot of an android phone, if I insert an exFat SD it doesn't recognize it and asks to format it (which leads to FAT32)
It may work with an OTG card reader tho.
Yes Sir!In the internal SD slot?
