Reamonnt223
- Mar 14, 2015
Shenzchen Audio has a download on their website where I bought it but the other file maybe called RUIZU_A50.HEX isnt there. Its a nice little player alright.
Use poweramp if you want to use eq on the g7 or uapp for non eq. I also have a g7 so trust me poweramp has the best eq for it (do not have root so do not know if viper4android is better). Although if you still want something better take a look at the hidizs ap80 my friend has it and I compared it to the g7 it is better.didnt try uapp yet, tried the hiby app and lg stock music player same results, tried turning off hifi quad dac, same too. I think its just the way lg works with their eq.
Maybe the HiBy R5 ?Is there any Cheap and good Daps with 4,4 mm balanced port? I have the LG G7 and the Fiio M11 but want something better than the G7 for cases when the M11 is too big to carry around. Something the size of the Shanling m0/ hidizs Ap80 would be perfect. Prefer neutrality in sound.
I should add that the budget is around max 200 usdMaybe the HiBy R5 ?
Have you activated the quad dac in lgs settings and chosen the hi res output?Im actually using poweramp all the time, still, the eq works badly, I believe its lg's implementation on the eq.
Either something is wrong or you just don't like the g7s sound lol. Can you post a Pic on your eq?tried that one too
Thanks, I will search again but it looks like the links have been deleted.
