mbwilson111
- Oct 13, 2016
please suggest dap under $200?
Cayin N3
with 4497? what about f audio's?Zishan dsd
I have the ak4490 and the ak4497 both good, I have the f.audio s1 and like it allot, almost bought the xso2 but decided on ak4497 dsd insteadwith 4497? what about f audio's?
The one selling now on aliexpress is the latest dsd version? like whats the difference between standard 4497 dsd and upgraded 4497 dsd? how does you describe dsd sound signature?I have the ak4490 and the ak4497 both good, I have the f.audio s1 and like it allot, almost bought the xso2 but decided on ak4497 dsd instead
Well on its own I would say fairly neutral, well extended highs and a very slight sub bass roll off ( easily fixed with eq ) but barely noticeable, I haven't heard allot of daps out but I can say it's better then fiio x1ii and x3iii (sound better and doesn't crash constantly over and over) I liked it better then a friends ibasso dx50 ( old but still good, little colder then my dsd) to me it seems pretty dynamic and very detailed but I havent listened to it stock in atleast a month, cool thing about dsd are the diy capability, you can change the sound using different op amps and other upgradesThe one selling now on aliexpress is the latest dsd version? like whats the difference between standard 4497 dsd and upgraded 4497 dsd? how does you describe dsd sound signature?
will you suggest a50? out of all can you rank them from best sounding?Output impedances measured by me:
AGPTEK ROCKER
0.235 Ohms/32Ohms/500Hz
1.98 Ohms/100 Ohms/500Hz
RUIZU A50
0.235 Ohms/32Ohms 500Hz
FIIO M7
1.31 Ohms/32 Ohms/1KHz
1.37 Ohms/100 Ohms/1KHz
xDuoo X3
0.28 Ohms/32 Ohms/1KHz
0.44 Ohms/100 Ohms/1KHz
xDuoo X3II
0.6 Ohms/32 Ohms/1KHz
0.74 Ohms/100 Ohms/1KHz
QNGEE X2
0.84 Ohms/32 Ohms/1KHz
0.93 Ohms/100 Ohms/1KHz
I am still thinking which to go for, my mind is set for many options and still open for suggestions. From where you bought opus and which one?Dragon, Keep in mind the dm6 is a low impedance, 5 BA iem. I was on the same boat trying to decide between the zishans and f.audios. I went with the Opus. Perfect to drive these BAs.
Thank you i will take a look at x2.For my best sound, within the range of € 50, is the QNGEE X2.
If you want more information you can read / translate my review:
https://auricular.org/5-reproductores-mp3-baratos/
Now I'm testing xDuoo X3, xDuoo X3II, Shanling M0. For me the best sound is xDuoo X3II, IMHO better than Fiio X1 (I and II) and better than Fiio X3II.
I have the DM6. I have a Shanling M3s, Shanling MO, Hidizs DH1000, Hidizs AP60 Pro, Colorfly C3 and a Zishan DSD 4497. The DM6 sound the best out of the Zishan DSD. If you look at the review of the DM6 by Hawaii Bad Boy, he even uses that to assess the DM6. I didn’t have to say that, but there are differing views on what gear is “right” and “wrong” for BA based IEMs.I am still thinking which to go for, my mind is set for many options and still open for suggestions. From where you bought opus and which one?
Yeah, there are different views about right or wrong of using sources with high impedance like dsd, I am still curious how dm6 sounds good with dsd. can you somewhat describe its sound signature ? its not my list too but i am backing just because of high impedance.I have the DM6. I have a Shanling M3s, Shanling MO, Hidizs DH1000, Hidizs AP60 Pro, Colorfly C3 and a Zishan DSD 4497. The DM6 sound the best out of the Zishan DSD. If you look at the review of the DM6 by Hawaii Bad Boy, he even uses that to assess the DM6. I didn’t have to say that, but there are differing views on what gear is “right” and “wrong” for BA based IEMs.
