Obscure Chinese DAPs
- Thread starter pekingduck
hqssui
- Sep 29, 2014
Just saw this listed in Penon Audio - F. Audio S1. Looks very similar to Hisoundaudio Rocoo series. Claims 35 hours battery life and has bluetooth as well.
https://penonaudio.com/F.Audio-S1
I'm done with Xduoo, between QC issues and firmware problems that they never resolve, I'll stick with companies that care about their customers.
Slater
Yeah, but maybe this dap won’t have any QC issues or firmware problems?
Lemme guess, you still believe in the tooth fairy and the Easter beagle too?
Slater
Haha, just joking around. I feel the same way lol
groucho69
How can there be no Easter Beagle?
I had the X2 for a short period, it wasn't half bad. I can't expect more for 50 bucks
mbwilson111
- Oct 13, 2016
I choose to remain optimistic about the new xDuoo...for now...
Just wait for serious reviews...
mbwilson111
- Oct 13, 2016
That is the plan. Of course I do not really NEED another dap. I like the look of the layout. I like buttons. No idea what the price might be.
groucho69
Of COURSE you need a new DAP, and DAC, and amp, and buds, and IEMs and cans and a money tree...
mbwilson111
- Oct 13, 2016
and a money tree...
If I plant some coins will a money tree grow?
groucho69
Try notes
NeonHD
I have this dap. I find the sound to be quite artificial in the mids and highs. But it does surprisingly power my Allessandr MS1 and ProSonus headphones reasonably well.
The UI is abysmal though. It regularly switches to ramdom play and/or repeat on song (over and over) untill you go into settings and change it. It does revert back on occasion though. The EQ only works if you press the right hand button after use, just coming back out of settings resets it . Its really hard to quickly turn the volume down if your on the go. Infact the only way to turn the volume down quickly is to pull the earphones out (you have to get back to the "now playing' screen and then press the back button till the volume -bottom right of screen - lights up, then you use the back and forward buttons to change it.
I think there will be better options than this out there. Its quite a frustrating device!
Jeez, that does sound kind of frustrating to use, and I thought the X2 had the worst software. Maybe I should just go with the xduoo X2 just to be safe.
