nick n
- Feb 3, 2011
Anyone try VE Monk+ with the Walnut?
Also, can you skip folders or just go to the next song? There is only so much you can do with buttons!![]()
Funny thing that just came back from a walk with those ( single foam and a bit of silicone swimmer earplugs stuck to the edges to secure them in ) .
Excellent driver control.
You'd be very happy.
Was a bit trippy in spots had to look around a couple times thought someone was around me.
This is with the above opamp. I'll get to them with the spare stock unit and PM you if I hear anything as far as noise.
* Monk + has the smoky shells right with the words MONK on it? I have earlier model also so lost track ( yes waaay too much stuff here )
**Tried a set of dual BA 103db/15 ohm nothing detected. Think that is the lowest ohm I own now unfortunately, so definitely trust/listen to T.R.A.N.C.E. for anything lower!
*** Reads tracks only, in order and regardless of folder boundaries to answer your question
