HolyCheese
- Jan 1, 2012
I couldn't find a thread on the O2 in the DIY section so I'm just going to ask here.
So, I soldered together my own O2+ODAC a couple of months ago and everything works fine so far. However, there might be few small problems.
Because this was my first DIY attempt, I didn't honor the "put everything in shortest to tallest" rule too throughly, and the regulators (U5, U6) ended up being too tall, which can potentially short to the case. I've checked, and there is around 1mm of space between the top to the case, but it might touch the case if the amp is held upside down or if I apply pressure to the board.
I've tried heating up the joints to push the regulators down a bit, but I cannot heat all 3 joints on the regulator at the same time and the top of the regulator gets quite hot during soldering which makes it hard to push down.
Can any experienced DIYer tell me if this could cause a problem, and if so, how could I fix it?
Buy something called a solder sucker, or solder wick (goat wick) And make sure to let the IC cool down between attempts. I'm not sure how long you tried but if I recal correctly overly heating the IC's can damadge them.
