Umm, so speaking of investment, how are you liking your Vygarde's outcomes so far? How would you evaluate its performance with the HD 600, as compared to previous, or other known contenders (that is, if it is not too early to ask)?
Excited that my clear Drausk has a new partner. Absolutely thrilled with how it sounds with the Wenge Auteurs (limited edition)!
(The Stellias now have a Draug 3… color match is opposite of the ideal, but I’m not going to bother to determinate)
The Vygarde is a tremendous cable for the HD-600. Soundstage is wider, space between voices/instruments is ‘clearer’. Bass seems to extend deeper without ‘bloat’. The Vygarde also takes nothing away from the HD-600 midrange capabilities. At the upper end of the FR spectrum, cymbals have the right sheen and the harmonics of strings emanate in true fashion. Highest recommendation!
I'm not sure whether it was sleeved or not--but the 1st Drausk pictures on the website showed a black Drausk (probably black PVC covering on each wire vs actual black sleeves). I preferred clear, so went with that.
There are 3 pvc covered non sleeved Drausk options.
Black (non transparent), Clear and transparent black (where you can actually see the copper wire)
Drausk lite has all the textile sleeved options (like Vygarde, Silvergarde etc)
Some cables offer both, like the Vykari which was available as non sleeved clear option or sleeved option like Silvergarde. (I own a black textile sleeved Vykari for instance)
