Noble Audio - the Wizard returns!
May 9, 2014 at 11:17 PM Post #3,976 of 36,066
  I just got my impressions done today. Before I think about sending them in, I want to ask you all for your approval. Will these work?  There's a slight gap in one. I don't know how much that'd affect the making of the CIEM. What do you guys think?
Fail
Noble Audio Stay updated on Noble Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
May 9, 2014 at 11:24 PM Post #3,977 of 36,066
Hi, my audiologist was pretty bad with making impressions and they turned out like the above.  Is there something different that other audiologists are doing to make better impressions?  Different types of material, etc..?
May 10, 2014 at 12:00 AM Post #3,979 of 36,066
I despise the "modern" impression syringe gun which for the most part yields horrible ear mold impressions.
1) The viscosity is usually low with such guns, so the audiologist/hearing aid dealer, as the lower viscosity requires less hand strength to squeeze out the material
2) due to the design of the gun, hand control is very poor as you have to keep the gun fairly far away from the ear
Imagine drawing with a long pencil, but only hold the very far end of the pencil....  you don't have much control, and the result is a poor drawing
The tool I prefer is, the old tried and proven
This type of tool allows for more control.
Why is the "modern" gun popular?
Answer:  Hand Strength & less mess
The Gun syringe requires less hand strength, and you don't need to mix impression material as it spews out of the gun pre-mixed.
May 10, 2014 at 12:03 AM Post #3,980 of 36,066
Try to get them to make them as best they can.
I provided these pictures to Noble and they were not 100% certain with mine, and in the next couple weeks I'll hear about their progress.  Where I live there aren't a lot of options and definitely got the best in my area, but as you can see they are not perfect.
Fingers crossed,
May 10, 2014 at 12:04 AM Post #3,981 of 36,066
Would you not be able to work with these at all? They definitely look better than mine.
In a situation like thise, we contact the customer, inform them that under our standards they "fail" but if they want us to "attempt" to work with them we will.  We would rather warn the customer that the ear mold impressions are less than optimal, before they get caught up in the "circle of re-fits."   As this leads to frustrated customers, wasted time, wasted money due to shipping fees, and longer waiting periods.
No one wins when poor ear molds are accepted.
May 10, 2014 at 3:58 AM Post #3,986 of 36,066
I also don't like the gun thing either, but for the opposite reason that they require a lot more strength to just pull the trigger, making it nigh impossible to control the mixing nozzle accurately, not to mention those nozzles are always very long. I went back to the syringe after finishing my first 8 cartridges.
I have to admit those cartridges are a lot more convenient, but they also have their own share of shortcomings. Personally I prefer the traditional hand mix technique where you can easily control the viscosity. Some ears might want it hard but some want it gentle, and I couldn't do that with the premixed cartridges.
May 10, 2014 at 4:14 AM Post #3,987 of 36,066
  Could you guys give me an example of a "perfect" ear mold?
These might not be your so called 'perfect' example, but they can give you a good idea of the standard your impressions should meet. The most critical factor here is that the canals need to be as good as possible, you would want them to be long enough, with no voids, cracks, chips whatsoever. Of course the technicians are able to fix them later but having defects means that your are raising the possibility of having a refit.
You also need to have enough base thickness for installing the sockets later, as well as having the impression material filled in all the crooks and nannies. Some people often forget the helix part and that's not good.
I made the ones below for a guy just last week, he had very small ears and thus I had to increase the vicosity of the material by mixing in less catalyst, something you cannot do with the modern impression guns.
May 10, 2014 at 9:04 AM Post #3,990 of 36,066
How long does it take for the impressions to be useless?  Other words, how long does it take for it to shrink significantly enough for it to be useless?  Also, I heard sometimes the impressions are 3d scanned, is that true?
