JaZZ
By reducing the amount of mass around the circumference, you lower the moment of inertia of the outer section and (thus) reduce the disk's damping requirement. There's less mass available to excite wobble (= vibration). It's not the inner section of the disk which excites vibration (by inertia and centrifugal force), but the outer section, which is much more affected by centrifugal force.
Originally Posted by nautikal /img/forum/go_quote.gif The vibration is caused by high frequency wobble. Are you going to back up your statement with logic and scientific principles, or are you just going to say the equivalent of "reducing the mass on the outer portion of the disc will reduce vibration because you reduce the mass on the outer portion of the disc?" |
