gimmeheadroom
How much time is actually adjusting the volume? That is something you almost never do, right?For example. 20 hours of usage per 4 days. How long you think it will last?
Maybe I don’t understand the potential issue that can be caused by using the volume knob and i am completely naive but me being concerned about that…….i simply don’t know what to say to this raised concern.How much time is actually adjusting the volume? That is something you almost never do, right?
agreedEverybody has different things they worry about. Bottom line, I am sure Lake People would be able to deal with replacing whatever if needed.
I do a lot. Why? Cause im not only Listening to music, but also spend time on youtube and gaming.How much time is actually adjusting the volume? That is something you almost never do, right?
There aren't a whole lot of choices in hardware volume control. But if you spend a lot of time youtube and gaming where you don't get bit-perfect, you could use software volume control for those cases.I do a lot. Why? Cause im not only Listening to music, but also spend time on youtube and gaming.
Imagine great song comming up when you gaming, You wanna blast it right? After that you go back to normal.
I abuse it a lot so that is the question.
When I bought the hd800 about 8 or so years ago, my audio store dealer was adamant that the hd800 needs tubes. He was pretty straight up about it. At the time almost off putting to me, the novice.How is the synergy with HD800S and niimbus 5. I haven't liked it much with Ferrum Oor alone haven't tried with there power supply Hypsos yet though i doubt that would change things drastically . One possibility would be sending back Oor+hypsos and buy niimbus. Or would that be a mistake again considering HD800S as my main HP. Oor on its own have been to dry and bright with bass and sub bass lacking. It Seems to focus much more on the mids and treble.
This post talks about using the HD800s with Niimbus.How is the synergy with HD800S and niimbus 5. I haven't liked it much with Ferrum Oor alone haven't tried with there power supply Hypsos yet though i doubt that would change things drastically . One possibility would be sending back Oor+hypsos and buy niimbus. Or would that be a mistake again considering HD800S as my main HP. Oor on its own have been to dry and bright with bass and sub bass lacking. It Seems to focus much more on the mids and treble.
Thanks thats good advice. But you have at least tried the HD800S with Niimbus but still preferred Wa2?When I bought the hd800 about 8 or so years ago, my audio store dealer was adamant that the hd800 needs tubes. He was pretty straight up about it. At the time almost off putting to me, the novice.
My experience soon after, and still to this day, showed that he was absolutely correct.
The advice he gave me back then, as he is a Woo audio dealer, is if you want an amp for just the hd800 (and other high impedance hps) go the wa2 an OTL amp.
If you want the amp to work with other hps as well in the future then look at the wa22.
The wa2 is silky smooth in its style.
The wa22 not so laid back.
And after that there is the joys and work involved in looking into, learning about, spending money and enjoying tubes.
I was happy to do that the first time round but could noit be bothered doing it again.
Most of my upgrades for about 12 months was pretty much tube rolling - note: quality over quantity/variety.
My main setup is now the us4 with susvara. I still own and use the hd800 exclusively with the wa2 as one of my alternative set ups.
That’s all from my own experience.
All the best
I have not tried the hd800s. Just the hd800 that I own.Thanks thats good advice. But you have at least tried the HD800S with Niimbus but still preferred Wa2?
Otl tube amps is the most noisy tube amps with most harmonic distortion? That's why they work with HD800S?
The niimbus is great with my susvaras and very good with my utopias but it may be overkill for headphones that are NOT hard to drive and "top end". Perhaps you will get more value and a touch of warmth and versatility with some of the latest offerings from the other art of the company - the violectric amps.
I believe they have less warmth than the v280/v281 but more than the niimbus.
I've lost track of their latest models but I am thinking of the v550 (I believe that's the one that started these new releases).
Maybe look into those if you haven't
Hope that helps a bit
As long as it would sound fullbodied and not to bright and harsh i would be happy with it and give it the best bass it can produce. While at the same time having great resolution and clarity.and the V280 did just add a touch of warmth, but not a game changer for me, while the added resolution and clarity from the US4+ was.
