Impression of the Niimbus US 5 Pro and Ferrum Hypsos OOR. Impression is based on the paring with the Utopia and Susvara.
I will be solely focussing on the sonic aspect of the two amps.
The width of the sound stage with the US 5 Pro slightly ahead of the OOR. The stage with the US 5 Pro slightly sounded wider to the left and right. This characteristic also gives the upper hand to the US 5 Pro in terms of separation. Whereas for the depth of the stage, the OOR has a slightly upper hand, some instruments sounded further back at the stage. It may be due to tuning and the blacker background in the OOR, it sounded there are more contrast between black areas and color, this creates a deeper stage. The black background contributes to the presentation of the stage and positioning of instruments on the stage.
For both amps. The size of all instruments and vocals are very well controlled with an accurate amount of space added between them, as if the resolution is enhanced slightly.
The tuning and tonality of the US 5 Pro is very neutral. I really agree with the sonical description that it is a reliable " tool " for music amplification. It does not have much sonical character or coloration to it. It is studio monitor quality neutral, it does not exaggerate your bass, does not add any additional emotion to the vocals, highs are extended and articulated as a studio monitor reference signature. It reveals exactly what is given to it from your upper front gear. It is extremely transparent to it point that it makes everything up front counts including your DAC, XLR analog cable, power cable and even your power source. It is a reliable Tool or a professional device for you to evaluate and compare your headphones and DAC. It is the most neutral and well balance amp that I have came across. Perfectly studio monitor neutral and reference quality in all aspects including tonality, details and staging.
The tuning and tonality of the Hypsos and OOR stack leans slight to the side of coloration for enjoyment. As most of us here have a general consensus that the tuning of the Hypsos and OOR leans slightly warmth of neutral. The higher frequency is also very detailed while being very well controlled in quantity to ensure no excessive hotness or brightness for particular headphones, while maintain the details it some how may masked off some unwanted artifacts in the remix. The tonality characteristic of the Hypsos OOR and tuned with one sole purpose in mind, is to create a musical amp that enables you to enjoy music at the top level of detail and transparency for an extended period of time without fatigue. The Hypsos OOR is not a neutral amp, it has a very slight tasteful coloration to it.
Though the two amps are placed at different price points. Both the US 5 Pro and Hypsos OOR are solid choices. If your preference leans towards the raw performance and wanted to reveal the original track as it is recorded as in the music mastering and production studio, the US 5 Pro is prefered. I would also give the upper hand to the build quality to the US 5 Pro. The amp is masive, heavy duty and the volume nob is like a tank. You are getting a Germany made level of craftsmanship and this tool will last literally more than half a centry.
