Exidrion
- Apr 15, 2008
Yeah, tht is a major annoyance with the Rag.
I'm new to The Schiit brand, recently buying a Jot and Bimby and loving them both. I started to think of buying a Schiit 2 channel stereo system and the Rag looked perfect - except for the lack of a remote!!! I'm sure the topic has been beat to death but I wanted to share my feedback with Schiit. If the Rag had a volume control, I'd have pulled the trigger tonight on one (along with a Gungnir MB). I don't need a fancy remote - it only needs to control volume and mute - but not having one is a deal breaker.
I was hoping the new 2 channel stereo products could fill the gap since the preamps do have remotes - but alas, there are no headphone outs on the preamp or amp.
I've gone without a stereo system for a few years now, so I guess I can be patient for a Ragnorok 2 to hopefully be released with a remote.
Why not go with this: Bimby -> Freya (remote control) -> Jot
God, I must be getting really old. I remember when you used to have to get up from the couch, walk all the way across the room, just to change the channel on the TV. Boy, those were the dark ages.
Have you tried shutting down and starting Yggy? I'm betting that does it.
First, what exactly makes the Adapticlock system shift from VCXO to VCO mode, so I can try to figure out what I did that caused this change?
And second, what exactly is "lower quality" about this mode, as it still sounds pretty identical to the way it sounded before?
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
1. The VCXO will attempt to lock the input word clock multiple to within a very few hundred ppm at most by dragging the inflexible but very stable crystal around. Should that fail, an error output from the VCXO triggers a VCO of much wider range (2) albeit less stable than a crystal to lock - the BBG light then lights.
I hope this is helpful.
In any case I assume the result in digital audio of the difference you are describing is an increase in jitter due to less accuracy in the clock ferequency?
