- Jun 23, 2014
David, Jason and others have said there will be "trickle down" technology from the Yggy to their lower priced DACs.
I have not, you must be thinking of Mike.
The "glassy/steely treble" you're hearing dos NOT go away… if you leave the Yggy as is… and depending on your ancillary gear…
Yes, the sound continues to improve, however this is w/ the Yggy being the least expensive piece of gear, incl. cables, except for a few PCs….
I however, in my system, DO NOT find it fatiguing at all… just detail driven, slightly thin & lacking a higher degree of analog flow… I strongly suggest you get other things in the system right, such as polishing/cleaning all connections on both ends.. also a Digital PC for Yggy… also feet/footers...
More than likely fuses, though I haven't tried yet...
Not sure what's better up to 5K..
David
So far yes, still takes a week (or two) to get back to "awesome" if left off even for a while. A minute or two to move the DAC... no big deal. More than that? Need to start over or at the very least a few more days. Keep in mind that no one has had an Yggy for more than a few months at this point. Things might be different a year from now.
Thanks for the feedback! I guess I won't be bringing it anywhere for a comparison any time soon!
Sorry friend, I thought the wink would convey the intended humor implied by assuming that the Yggy will surpass the Hugo
IIRC some DAC's out there with ENOB of 21 (Vega, DAC2 HGC) as verified in Sterophile measurements.
Why you no sell Iggy to your cousin after two days?
Every component has a sound signature no matter how high end, and system matching is always important. For me it is about maximizing the sound for a given budget and doing that with proper system matching. At the level of my current system, the Dac is no longer the weak link in the chain. All other combinations were improved with Yggy in the chain. So I am happy working with it and playing around with other factors as I continue to improve my system. My feeling is once you have a highly resolving source, it is easier to tell the differences and limitations in other components.
Get out the cheese and wine and have others come to you!
I'm very interested in how the Yggy compared to Chord Hugo, anyone with any impressions?
You can't verify DAC relative accuracy with Stereophile measurements. Completely different thing.
In any event, I found that Yggy easily outresolved Vega, which was already pretty darn resolving (only be surpassed by two or three other DS DACs). Not to mention other aspects you already mentioned.
I totally understand.
I do believe in component matching and synergies, but the Yggy is so resolving without any warts, that perhaps tonal or timbral coloring is best accomplished later down the chain with amp or transducer. Let's say I preferred a warmer more lush sound. It would be stupid to buy a less resolving but warmer DAC to start (usually for more money) because that ability to reproduce low-level information is already not as good. Easy to make things sound warmer, leaner, etc. Difficult to make things sound more detailed than what's on the recording or have less strange artifacts.
I have that option to change sound because I use a tube amp.
Thats why I would only recomend a tube amp to anyone looking for an amp.
I wont want to be responsible for suggesting an amp that is "fixed" in signature,
which is what all Solid State amps are..
Those amplifiers with discrete output stages are probably "fixed" in design.
