Quote:Originally Posted by bfreedma It's not 1995 any longer. There is no technical reason why Schiit can't develop a stable Windows driver like hundreds of thousands of other companies have in 2015. And we do have stable Windows drivers for the tens of thousands of USB-equipped DACs that we have sold. However, with Yggdrasil's new USB input, it's important to test for interaction between the older and newer drivers (do the old ones need to be removed? Are there conflicts if you're running both versions?) and for overall stability. Wash, rinse, repeat for the innumerable versions of Windows, including the "invisible" 32/64 bit variants, on the innumerable types of systems, etc, etc, etc...this is not trivial. And--the thing that is completely inexcusable--this is simply because Windows does not support USB Class 2 Audio Standard, even in Windows 10. It is the only major OS not to do so. Mac is plug and play. Linux is plug and play. Hell, Android 5.0 is plug and play. No drivers, just plug and go. And yes, even with stable drivers, a large part of our tech support is for Windows drivers issues--permissions problems, trying to install it on unsupported OSes (Windows Server, for example), conflicts with other drivers, etc, etc. Frequently accompanied by a haughty attitude and arrogance (How dare you do not make my factory-gimped OS work as seamlessly as other platforms? I have built 26 sooper-dooper computers with Arglebargle motherboards and USB 3.2 and I was on the team that designed the Pentium!!!!) So sit back, relax, and know that we'll have stable Windows drivers, for the foreseeable future in which Windows remains the only platform that does not support this almost decade-old USB Audio Class 2 standard.
