sithjedi333
- Dec 23, 2006
So the way to get your order is to threaten to cancel and you will get it in 2 weeks?
Well I complained so they hurried mine a little, and then they sent it to the wrong address, and when I told them, they first said I was wrong, so I proved it to them, they implied it was because I had rushed them that the mistake occured.So the way to get your order is to threaten to cancel and you will get it in 2 weeks?
JHA only really want pro customers IMHO. They should be honest about that and stop taking consumers money.
The latest happy episode in my Roxanne love story:
[COLOR=1F497D]Hello,[/COLOR]
[COLOR=1F497D]I think you are just trying on purpose to provide me with the worst service ever. I sent you two emails to change the shipping address, and was concerned that you had NOT done it because the shipping address on the website was still wrong. Your answer was the following:[/COLOR]
[COLOR=1F497D]“We update addresses in your folder, not on the website because we ship from your folder. Your order should be shipping out in the next few weeks.”[/COLOR]
[COLOR=1F497D]However, I just received notification from Fedex that my package was going to be delivered at my old address in Shanghai. I now live in Beijing and told you so. You confirmed you changed the address and you actually DID NOT. This is going to cause an endless hassle for me from Chinese Fedex and the Chinese Tax Office that I ABSOLUTELY WANTED TO AVOID.[/COLOR]
[COLOR=1F497D]I really do not understand what you have against me, but you are really making my life MUCH harder.[/COLOR]
[COLOR=1F497D]Thank you for nothing.[/COLOR]
[COLOR=1F497D]Michael[/COLOR]
Rudi,
I have a question. I could be totally wrong but I thought the Roxanne's cable is eight wires, one for each of the bass, mids, treble and a ground on each side. If so, how can a balanced amp whether TRRS or Kobiconn imput with only 4 positive channels work? Does the fourth wire on each side become a overall positive lead? Thanks.
It's separated within the earpiece, hence the 4 pin connector.
1 positive per monitor separated into 3, the lead going to the bass pin is attenuated.
Thanks. But how do you achieve a balanced signal, wouldn't you need to separate the what was the ground into three positive channels.
For every iem with a 3-way crossover the signal is split. 1 positive split into 3 different frequency ranges
The Roxanne just carries that split outside the iem all the way to a common positive signal.
Hope I'm making sense.
Like I suggested earlier, the Roxanne could very easily be converted to a 2 pin connector using a resistor inside the iem instead of the attenuator.
Yeah, I think the Roxanne could easily be redone using 2 pin connectors.
I believe jh will be switching to the 4 pin for their entire product lineup.
I know they are changing to 4pin for all their model not sure why, perhaps they want to have adjustable platform like Roxanne.
Btw how to achieve with 2pin as it required the wire to adjustable resistor .eg.. the Roxanne. The bass is go thru the adjustable resistor, mid and treble to to the cross over directly.
Btw how to achieve with 2pin as it required the wire to adjustable resistor .eg.. the Roxanne. The bass is go thru the adjustable resistor, mid and treble go to the cross over directly.
