ikilledversace
- Jun 21, 2010
Null
The problem isn't really the wire but it's the sleeve that's the biggest problem.
The issue is mainly because of the plastic sleeve that protects the wire strands. The wires may discolor a little but it's the sleeve that turns greenish and ugly.
The insulation is only turning green because of the oxidization process.
Enamel coated wire will prevent it.
Sorry, this has to be asked. What's the benefit of 12 drivers?
bump.
I believe it's as simple as the more drivers the less work each individual driver has to work. This should equal a much better sound as each driver is putting it's own muscles into the corresponding task and are sharing with each other the workload. Now this and freqphase where each driver is outputting sound almost at the same time should produce phenomenal sound.
since when? have you email JH to see when is your eta?
I feel the same. To have waited since October, doing anything but seeing it through now would seem like a complete waste... doesn't change the way I feel about it all.
Another week goes bye bye. Any news for you? I was hopeful you would have gotten an email from Fed Ex this week.
