John Buchanan
1. No. You can buy much cheaper delta-sigma DAC that would sound the same. Except they don't. The Conductor 3X sounds better than the Mytek DSD 192 DAC.
2. No. Too much background noise. And that depends as well - very sensitive IEMs may be a problem. The Neumann NDH 20, AKG K701 and Beyerdynamic T1 Gen. 2 - no background noise.
1. The DAC section of the Conductor 3X is really, really good. I haven’t tried it on its own yet. But I also have the Burson Swing and love it feeding my Gilmore Lite Mk2 and Cavalli Liquid Carbon 2.0. The DAC section in the 3X is a soup up version of Swing. So chances are, it should have stellar performance as a stand-alone DAC if you want to use it that way. I like it better than the DAC in the Conductor V2+, which I previously owned.I like to understand this:
1. Does it make sense to buy the Conductor 3X as principally a standalone DAC? How does the DAC section compare to others in the US$ 2K region?
I had the earlier version of the Conductor SL and the DAC then doesn't impress me. However, it looks like people are comparing the new Conductor 3X with Mytek and didn't come up short?
2. Would the Conductor 3X be suitable for low level listening with sensitive phones, given that it has such higher power output?
I have read that some class A amps sound best only when driving loads that present a little challenge. Would the Conductor 3X fall into that category?
i would consider the c3x if i was looking for an integrated dac/head-amp unit, but i would explore other options if i only required a dac separate because there are many at different price pointsI like to understand this:
I don't have the Arya's, but I do have the Hifiman HE6se's, Susvara's and HE1000se's. The 3XR has no problem driving any of these headphones while sounding good doing so. The synergy is great with Hifiman headphones. But the 3XR sounds good with any planar or dynamic headphones I've played through it. So you should not have any issues driving the Arya's with this amp and have them sound good. It's the best I've heard the HE6se's sound, btw.Anyone try this with the Hifiman Arya? Surely it has enough power, but wondering if the combo is good (synergetic). Thanks.
I do like the feature set of the RME ADI-2 but it doesn’t have a balanced output. I like driving all of my headphones balanced. I’ve never heard an SPL amp so I can’t really comment on the pairing, unfortunately. The RME ADI-2 is a heck of a DAC and would go well with any amp you choose.Thank you, very helpful.
I'm looking at several options, but right now leaning towards the RME ADI-2 DAC FS and then a SPL Phonitor ex amp.
I do like a AIO solution like the 3x, but the option above also has its advantages.
Edit: I see you have the HeadAmp Gilmore Lite Mk2. I do as well, and tomorrow when I receive my Arya's will be using it to drive them. So while I'll be able to make up my own mind, I'm wondering what your opinion is about the Mk2's ability to drive them and the synergy it has with your other Hifiman headphones (according to HeadAmp the Arya and Mk2 are a great match). I could sure save some cash by just sticking to my existing setup!
Do you have a link to the announcement?Also, later this year a new power amplifier to replace the Timekeeper Virtuoso.
