NEW - Campfire Comet and Atlas
Aug 2, 2020 at 9:43 AM Post #3,286 of 3,472
are they a lot bigger than the Vega?
Not really, they are deeper and heavier. But then you can wear them cable up or down.
They also sound a lot better than the Vega.
Aug 12, 2020 at 5:59 AM Post #3,287 of 3,472
Hey all - I just got the Atlas and found it in desperate need of burn-in. After about 24 hours bass in tightening up and mids are less recessed. I think they sound fantastic with the CA silicone tips, good the CA marshmallow tips, but pretty awful with the Final Audio Tips. My issue is the Final Audio tips fit me much better. Anyone have a similar experience with the Atlas and any recommendations on alternative tips. Much thanks.
I've pretty much settled with the stock wf1000xm3 tips, they grip so well and since the tips come with a short shaft and a really extended wing it makes all the more the perfect tip for a heavy bullet type iem such as the atlas. Not to mention they also create a vacum when you squeeze them (see attached photo). 20200812_175817.jpg
Aug 15, 2020 at 9:19 AM Post #3,288 of 3,472
Hey guys... got my Atlas. Love them, the sound IS much more resolving than the Vega... BUT wanted to check something. It seems that the left one has a bit of a gap in the split-line at the top (see pic).
Does anyone else’s Atlas look like this... or have I got another duff?
I don’t know if I’m being a bit OCD, but you can clearly see into it, and worried it’s going to be a bit of a dust collector.
Thanks in advance guys and gals.
Aug 16, 2020 at 1:22 AM Post #3,289 of 3,472
That gap looks awfully big. Try to check with cfa about it cuz that sort of things are considered b stock.
Aug 16, 2020 at 1:46 AM Post #3,291 of 3,472
Aug 16, 2020 at 2:25 AM Post #3,293 of 3,472
Thanks for posting... yeah yours are completely gap free from what I can tell. 🧐
A bit dirty but yeah, gap free. Hope yours get sorted out soon though.
Aug 16, 2020 at 6:41 AM Post #3,296 of 3,472
Maybe as CA were kind enough to swop them for your used Vegas they gave you B stock? Mine have no gaps.
