New: Burson Audio Play Amp/DAC (2W@16Ohm) (op-amp rollers dream)
Nov 6, 2018 at 6:19 AM Post #887 of 1,256
Hello guys!
One quick question.
There is any "good knob level" on the Burson Play!? I am using it at 55, but is that ok? The too high volume could damage my Play! unit or nope? The higher knob level could produce more heat, or is it possible that creates dissortion in the sound?
Any advantages or disadvantages using it on a higher volume level?
Thanks in advance!
Cheers,
kebcy
Nov 6, 2018 at 6:36 AM Post #888 of 1,256
that is to drive a week and decide what I need ?
If you intend to purchase a PLAY and you're not sure if you need the BURSON opmaps inside or not, then it's all about your money. I kinda like more the Classic V6 opamps then the default NE5532/5534, but it's all about how much money you want to invest. In synthetic measurements NE5532/5534 are as good as the others, so...again, all come to the money.
If you already have the Basic PLAY, then my best sound and lowest possible noise was with 3xAD8599 (SO8-to-DIP8 adapters) + 2xAD797. Also, 3xMUSES8920 + 2xAD797 was about in the same leagues as the above.
Nov 6, 2018 at 6:44 AM Post #889 of 1,256
Hello guys!
One quick question.
Thanks in advance!
Cheers,
kebcy
Very good question indeed: you need around 52% for 2V RMS, but could be anything between 45-55%; after all, depends what you intend to drive on the RCA plugs. 55% is probably around 2.2V RMS, some speakers amps might have an issue with that, as their input stage might distort (same applies to Objective2 headamp if gain is >3X). Of course, when driving cans on the 6.3mm plug, always start with a much lower volume, like 10-15% and don't use software to control the volume, just use PLAY's knob.
Theres no need to use more than 55% of power if you intend to drive an external amplifier, it won't help and yes...PLAY could get a little bit warmer.
BTW, PLAY is never hot, it is just warm, up to 40C on top. Matrix HPA-3B is hot: 55C on top, sometimes. :)
Nov 6, 2018 at 9:24 AM Post #890 of 1,256
Is there a dual AD op amp that you could recommend that comes in the DIP 8 form?
Nov 6, 2018 at 10:22 AM Post #892 of 1,256
Where are you all getting your 8920's? When I go to Mouser.com it says I'd have to order 2000. I don't want to do that. I'm distrusting of EBAY and Amazon. So I'm not really sure where to get them.
Nov 9, 2018 at 4:06 AM Post #896 of 1,256
Default NE5532/5534 should do just fine, so just give it a try. Of course, Classics might increase the soundstage a little bit, but the default opamps are just fine. I can't recommend the Vivids, it will increase the trebles and scene a bit too much and might not be the perfect pair with the K712.
Vivids may work quite well in LPF and Gain, just not in I/V for the K712.
I have Classics in I/V with Vivid in LPF and Gain. It's a bit more fun to listen than when using even one more Classic in LPF. With 3 Classic I found the sound quite boring no matter at what I listen.
Very good question indeed: you need around 52% for 2V RMS, but could be anything between 45-55%; after all, depends what you intend to drive on the RCA plugs. 55% is probably around 2.2V RMS. :)
It seems the output voltage may slightly vary depending on what OP-AMPs you use. For me with the combination I've mention I have 2V at 47. If using all vivids I have to go at 45.
Darn - can't find 8920 in stock
I've told you few posts ago how I buy my Muses - not from online shops like Mouser or DigiKey but using the local distribuitors.
Just go on the link with the warning about fake products and you will get a list of authorized distributors. You can contact them to tell you where to buy.
Nov 9, 2018 at 4:47 AM Post #897 of 1,256
I wish there could be a direct and easy channel from Muses in Japan to us, their international customers. When I went there opamps (and all other audio related stuffs) are much cheaper than on eBay, and there wasn’t any reason to worry about fakes. The sad thing is you’d have to walk around to get great deals. Sometimes there are good deals on Yahoo Auction but it still doesn’t compare to the local shops
Nov 9, 2018 at 4:58 AM Post #898 of 1,256
If you can find a good forwarding service (tenso for example) akizukidenshi is the place to buy muse op amps in Japan online. You can get Muses 8920 for 480 yen each.
That is the website I used for mine.
Depending on how cheap you can get the forwarding service to send them, they are a great option as they sell the real thing.
Nov 9, 2018 at 5:54 AM Post #899 of 1,256
For Europe the main distributor I could found using that link I mentioned - for almost all countries - is Rutronik - they have local reselers. I contact them, they gived me contact for local reseller. Had to wait about 2 weeks but I got them at half price compared to Mouser.
This is the final page you get accesing the link - https://www.njr.com/sales/index.php
I don't know why Mouser and Digikey are promoted so much so you need 2 pages to get the distributors list.
