The simplest way is to ask Jos, but normally the r2r 7 ships with the smooth fw. For the first 800 to 1000 hours, i recommend you keep the smooth fw. Otherwise, you may find you dac harsh. The first 24 hours are to be ignored: it will probably sound pretty bad. And one last advice, never turn it off so that it is always ready to perform, temperature needing to be even inside.
I see this on the R2R-7 user guide:
"We highly recommend to turn off your device when it is not in use."
