DACLadder
- Feb 16, 2013
RG402 works well for short 50 ohm cables. I bought from this Ebay vendor as I could buy in 2 inch increments for a custom install. They work well but have cheap connectors and may not be durable for years. But are fine if you plug them in and leave alone.
https://www.ebay.com/itm/BNC-male-p...-/172379907208?_trksid=p2349624.m46890.l49286
The Huber+Suhner cable from AfterDark is RG402. May be better built wire but the specs are similar to other RG402 cable stock. Hope AfterDark uses better BNC connectors. RG402 wire will handle voltages up to 1.9KV so there is no fear a 10M clock burning it out.
https://ecatalog.hubersuhner.com/media/documents/datasheet/en/pdf/84003502
