sajunky
Correct. You can't select USB transfer mode on the control panel. A reason is that USB host (PC) is negotiating transfer mode, USB sink device (Amanero) must accept conditions, there is no other way. It is why user is responsible to configure PC accordingly.Sorry but you write "the computer is always asynchronous, if it is correctly configured"
How to know if the computer is correctly configured in asynchronous mode
On the front panel of my R2R7 (upgrade in 2019) I cannot select the clock synchronized internally or externally .... I select my amanero driver on my pc and on my Dac I select os8 for example and I deactivate it didthering and the PLL (tda)
On Foobar 2000 it is easy, just install WASAPI plugin (the latest version has WASAPI built-in) and select the output device "WASAPI event".
On other players is all different, by example in Roon find WASAPI output in the General section and you must also tick an option "use WASAPI event driven mode" in the Advanced section.
