FredA
- Dec 15, 2013
Dithering has no effect IMO. I don't think it is supported anymore.I just bought an R2R7 from 2018 modified to become an R7 (Pannel, USB power supply, Accustillon) since yesterday, so I have little experience
I use it in USB with a PC equipped with the USB Matrix H card ans a Neotech Usb Cable
I don't know the Firmware used but it is the one from the end of 2019
I don't understand what dithering is for
Do you use it? I don't hear a difference
What setting do you use?
At the moment I am comparing
OS x 8
0 8 0 0 6
and
Our
N 3 0 0 6
In both cases I find the sound very soft!
As I only listen to PCM FLAC
is there a way in Jriver to switch from PCM to DSD to see if there is any improvement
This dac needs 24h of warm-up to sound as it should. The newer iterations do no need much time. It's something to know. Ideally, never turn it off.
IF you can't hear any difference between nos an os8, maybe the settings cable is disconnected.
The usb input is not the best one. You can have better sound using i2s or even spdif.
